Question about Garden
Ryobi PCN 3335 safety brake
Can this be adjusted
  • 2,220 Answers
I might arrempt to adjust it. I'd consider taking it to a chainsaw sales/repair facility for a quote if nothing else. I'd also consider removing it entirely. But I always wear full PPE when operating a chainsaw and I have 3 or 4 saws that were never equipped with a chain brake.
Posted on Sep 05, 2009
Pcn 3335 chainsaw brake will not release fully, what can I do?
ck to see that arm that hooks brake to saw is allowing full movement , on mine sawdust gets build up behind it and wont allow full movement, brakeclean is a great cleaner for this dont get it on painted cover !!!
Mar 02, 2015 | Garden
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chainsaw chain brake on Ryobi PCN 4040
remove the cover and check the spring
Apr 13, 2012 | Ryobi Garden
Repair manual for ryobi pcn4040 chainsaw
Got the same problem. narrowed it down to the tension spring in the brake handle you can buy then for around £4 of the internet. as yet i haven't figured out how to replace it yet.
My Ryobi chainsaw PCN 4545 overheated
Sawdust/dirt build-up helps cause this situation. Usually, the band is deformed so that it drags. The melted case parts may or may not need replacement, but will likely need trimming. The band usually does as it is difficult to remove the small bends in it. After repair, make sure the chain turns freely by hand. Set and reset the brake several times to make sure it works correctly. The clutch outer drum rarely deforms when this happens. Hope this helps!
Jun 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Hi, I have a Ryobi PCN 4545 petrol Chainsaw that i have owned for about 4 years with little use. I went on a Chainsaw users course over the weekend and took the saw on the instructors recommendation....
You probably don't want to hear this, but there have been many many problems with this unit. It is now, discontinued, Personally, I would get another one, any other one. To have any chance of any type of repair, you must get a service and repair manual. I have searched extensively but have been unable to find any manuals other than the User, one supplied.
Above is an exploded parts diagram, that should be of some help.
May 25, 2010 | Garden
Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Sep 28, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
311 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
