Question about Panasonic Televison & Video
Lamp is shutting off on PT-AX100U projector after 3 minutes. Must cycle power to get it to turn on again, at which time it will stay on for 1-3 minutes and shut off again.
  • 6 more comments
  • Mark1000 Oct 24, 2008
    about 400 hours, I have had the projector for 13 months.
    Neither the lamp replacement or overheating indicator lights are lit when the lamp turns off. I have cleaned the filter as directed by the manual, and it did not change the behavior.
    The unit is also making a strange sound, like some electric motor or servo is running for a moment but cannot actuate something and then stops (kind of an "errrrrrr" sound). It will do this twice before the lamp shuts off. I have not heard it make this noise before I had this problem.
    It is the original lamp which I understand to have a projected life of 2000-3000 hours. I have not tried changing it yet because it is an expensive component.
    Assuming that the unit has made this sound in the past, and I didn't notice it before, it could be that the lamp element is fractured or somehow opens up due to heating. That makes sense and may be worth a try. Any idea where I could get the best deal on a new lamp?
  • Any Guy
    Any Guy May 11, 2010
    Hmm a weird buzzing noise. Kinda hard to judge without hearing the noise. Could be a fan seizing up, could be the lamp ballast buzzing before it shuts down. I hate to be the bearer of bad news, but I'm thinking you might need professional help on this one.
  • Any Guy
    Did you use an original lamp? What I'm thinking is that the lamp is drawing too much current, which could point to a defective lamp. I have seen perfectly "good" looking lamps have this problem. The alternative is that the lamp ballast, also called the lamp driver has a problem. The reason I asked about the original lamp is that some of the aftermarket lamps have, in my experience, exhibited problems such as shutdown, premature failure and insufficient brightness.
  • Any Guy
    How old is the lamp?
  • 320 Answers
You can PROBABLY eliminate the lamp as the source of your difficulty then. The buzzing puzzles me, but without being there, I don't reallt have a guess as to what is causing it. Here's one thing you can check, after the lamp has cooled, pull it out and check the lamp socket for any sign of corrosion, arcing carbonization, etc on the socket. Could be that the socket is arcing after the unit heats up. It's a long shot, but worth checking.
Posted on Oct 24, 2008
  • 1 more comment
  • Any Guy
    Any Guy Oct 24, 2008
    I always start with Amazon for lamp pricing, though they aren't always the cheapest. Do your internet search and I would stick with an OEM lamp. There is one aftermarket company selling lamps that I trust and that is OSRAM, they have years of experience in the lighting industry. BTW, if you liked my help, please rate my response. Thanks!
  • Any Guy
    A clarification, check both lamp sockets, the one on the lamp and the one on the projector.
  • Any Guy
    Thanks for the rating, it is appreciated!
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
Projector powers up, after 2 minutes image goes away, projector goes into cool down, then shuts off. why?
FAULT: lamp of your projector is faulty.
Experience: when lamp life is near to end and environment temperature is too low you are facing the same problem and if you are facing this problem in normal temperature then also lamp is faulty.
Sulotion: Just replace the projector lamp
Jan 07, 2011 | Panasonic PT-AX100U-EC DLP Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
2. Press the ENTER button, and then press the F or G button
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
My PT-AX100u will not turn on. The lamp is new, I have done the iris fix, which didn't help. When I turn it on, the green light flashes and after 30 seconds, it goes into shutdown mode and then one red...
Yes please call me Just went thru the same issue with my customers projector it involves more then typing can fulfill. Thanks Jordan Thomas
910 538 2754
PORT CITY AV
Nov 22, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
http://www.youtube.com/watch?v=6jGwB05_gdk
May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
What could be wrong with a Panasonic ax100u with a blinking red light? I am told the lamp might be bad. Could it be something more serious?
if the lamp has been used for more than 1500 hours, then it could be a lmp problem.
1.check the lamp physically for melted filament,cracks etc or white deposits on reflector
2.If yes then lamp for sure is defective
3.if the lamp shows no signs as mentined above than it could be the ballast!
Jan 06, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector PT-AX100U
lamp blown? if not try this first
worked for me
Oct 09, 2008 | Panasonic PT-AX100U-EC DLP Projector
Projector self power off
Have you tried looking to see if the lamp has expired? Or could simply be cause by a faulty power supply unit?
Jan 13, 2008 | Office Equipment & Supplies
Televison & Video Logo
146 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
