Question about LG RH177 DVD Recorder/HDD Recorder
LG RH1757 HDD/DVD Recorder
Why wont my DVD play shop bought dvds.
I bought my player in Lanzarote, the canaries, Spain, where I live.
The region on the back of the player is 2, the dvds are region 2, yet the recorder just ejects the dvd, and an onscreen message says "unknown format", or sometimes "no disc".
YET....
when I put in an originalyl blank dvd but recorded on my other DVD recorder (a Philips), it will play on the LG ok, meaning the LG recorder/player works fine, and its a disc read problem..
So...
why wont the LG read shop bought dvds
  • Anonymous Dec 08, 2008
    I have the same problem. It will play homemade dvds but not shop bought. Very annoying
  • l3utterfish Jan 05, 2009
    same problem on a similar LG (When I want to play a DVD in a LG RH7823W DVD recorder I get unknown disc displayed)
5 Suggested Answers
SOURCE: Need to play region 1 DVD in region 2
Press Setup on Remote
Scroll to lock
Press 0 (seven times slowly)
Message appears you are region free say yes
Posted on Jun 20, 2008
Hi I got a Lg HDD/Dvd Recorder Model RH1999H. Ihave a problem copying Dvd from the hardrive. When I load a completly blank disc, the recorder will not intialize the disc. How do get this recorder to intialize the disc to video. When i got to set up mode, I select Disc Format option, i cannot get into the format mode, I tried to change it but it does not change the only thing I see on the disc format mode is PBC highlighted.
Please advise
AmarE-mail nikraj@telkomsa.net
Posted on Jul 25, 2008
SOURCE: LG HDD DVD RH1757 region code problem
Press 'setup' on the remote
Scroll down to the 'lock' icon
Press 0 seven times - you'll get onscreen confirmation.
Posted on Nov 08, 2008
SOURCE: Can I make my LG RH4820W HDD/DVD recorder multi region?
1 Power on the DVD recorder
2 Press "open"
3 Press "0000000" on the remote control slowly
4 Congratulations' will display on the screen if setup was successful.
5 Press "enter", then finish
Posted on Feb 16, 2009
  • 208 Answers
SOURCE: LG RH1757 (80 GB) DVD Recorder / HDD Recorder
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Posted on Mar 18, 2010
Code to unregional set my dvd player
go to http://ifndef.altervista.org/index_eng.html
a lot of helpful stuff about this unit
including instructions on making your recorder region free
if you do not understand the stuff on that site i strongly reccomend leaving it alone (easy to break, hard to fix)
Dec 06, 2008 | Televison & Video
2 Press "open"
Nov 19, 2008 | LG RH-4820 DVD Recorder
Oct 21, 2008 | LG RH177 DVD Recorder/HDD Recorder
Live in region 2 want to play region 1
To unlock all regions:
1.Press Setup on remote
2.Scroll down to Lock icon
3.Press 0000000
4.Regionfree!!!
Jay
Aug 26, 2008 | LG RH1999H DVD Recorder/HDD Recorder
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
hi
try a search on your dvd here check for region codes dvd
riz.
May 31, 2008 | LG RH177 DVD Recorder/HDD Recorder
Playing region 1 DVDs in LG DR165 receroder
go to dvd set up then scroll dow to lock then push 0 seven times
Jan 23, 2008 | LG RH177 DVD Recorder/HDD Recorder
My DVD recorder won't play my CDs
Recently purchased a unit... You can imagine the joy when I found in Manual: Audio discs can only play if in .mpg or .wma formats! Yes, all the bells and whistles except the most basic of functions such as all common audio formats. Other portable $99 dvd player works with them.
Dec 07, 2007 | LG RH1999H DVD Recorder/HDD Recorder
LG RH1999H DVD HDD Recorder
1. Turn machine on
2. Use remote to open disc tray
3. Use remote to go to setup area of menu (Home - Left) and scroll down to 'Lock' symbol
4. Press 0 seven times
Oct 29, 2007 | LG RH1999H DVD Recorder/HDD Recorder
LG RH177 DVD Recorder/HDD Recorder Logo
153 people viewed this question
