Question about Canon Office Equipment & Supplies
When i print colour document it comes out blurr
Multi purpose machine
  • 4 Answers
Make sure you clean the cartridges head first and you use canon utilities to clean the head of the the printer, Reset the cartridges and then try, it should work out for you.
In case if it doesnt work, run canon diagnostic tools through canon printer utility tool.
Posted on Feb 13, 2012
Ink is faint
two possiblities
1)not enough ink for the saturation of the media
2) media is not correctly saturated by the ink
sounds like the same issue- let me explain
your image may be purposely printed light because of 'ink save printing'( driver cuts down reqired ink levels to give a draft print.)
or your problem may lie with the paper type itself,
firstly have the machine print off its internal demo page ( read user manual to find how to print)
this print being held by the printer cannot be affected by external controllers, if the demo page looks nice aand even and strong in colour then your issue is software related and you should have a look at how the pc is handling these documents before they get to the printer.
if the demo image is light then you have a problem inside the printer
if it is the latter please re-post as internal demo page printing light in colour
Mar 16, 2014 | HP Officejet 4622 Multifunction Inkjet...
LABEL PRINTING
you might try downloading a template from avery.com that is what I use.
Mar 12, 2013 | Office Equipment & Supplies
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
When i go to print a document the printer just ejects a blanck paper i tried to print different documents but i always get the same result? I also check the print quality i get all the colors but black and...
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jul 09, 2010 | Brother MFC 490cw Color Inkjet...
Printer is Brother MFC215C. Cyan colour not coming
  1. Press Ink or Ink Management key on the control panel of the machine.
  2. Press 1 to choose 1.CLEANING.
  3. Press the up or down navigation key to choose the Black, Color or All you want to clean, and then press Menu/Set or Set.
The machine will clean the print head automatically. When cleaning is finished, the machine will go back online automatically.
Note If you clean the print head at least five times and the print has not improved, please contact Brother Customer Service from "Contact Us".
Feb 15, 2010 | Brother Multi-Function CenterĀ® MFC-215C...
Hi! My name is Roy Napier and I have couple of problems for which I would like your advice. 1. On some occasions my print-out has faint extra "ghost" copies of the text etc printed plus the colours seem to...
My first suggestion to you is to remove, clean, shake, and reinsert the ink cartridges, then allow the printer to self align. Follow your manufacturer's recommendations for removal and insertion of the cartridges.
The dragging of colour that you mention is most likely attributed to the rollers which feed the paper. If one is dirty, it will affect the paper's print quality. The way that I suggest to fix the problem with dirty rollers is to obtain a long, continuous piece of brown paper towel (utility towels, like you find in factories) and insert the end of the paper into the multi-purpose feed, then feed it into the printer for a few seconds.
Once the paper towel has fed into the printer, extract the paper manually by pulling on it in the opposite direction of feed. Repeat this process a few times and the rollers will be clean, and the color scrubbing problem should cease.
Dec 29, 2009 | Dell 3100cn Laser Printer
I cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
May 09, 2008 | Brother Multi-Function Center MFC-240C...
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
26 people viewed this question
old marine
old marine
