Question about Uniden GMR-1088 2-way Radio Walkie Talkie Dual Pack with NOAA Weather Alerts
If i go away for awail do i need keep them charged or leave them dead ?
If i dont use them do i keep them charged or drain them ?????
  • Uniden Master
  • 1,654 Answers
To keep the battery active you should charge it once a month during the season you are not using it. Do not leave the radios on the charger for an extended period of time, as this will age the batteries more rapidly.
Best regards.
Posted on Feb 17, 2012
Left key on for few days battery dead I jumped it off and runs very rough when give it gas gauges go out and backfires
Hi Did you leave the jumper battery hooked up while it was running? It sounds like the dead battery may need to be replaced. Jump it again and leave the jumper battery hooked up and then see if it runs ok. If it does run good you will need to replace the battery. I hope this helps. Rod
Aug 14, 2015 | 2004 Suzuki VL 1500 Intruder LC
Tip
Laptop preventive maintenance
After purchasing laptop when you are charging it first time take care that
power should not be absent meanwhile. If so happens after 80% charging then it always charge upto 80% offenly. Dont spill a water or tea on keyboard.Dont leave laptop in alone without lock dont put it in a conjusted place always keep open to free air dont expose it to sunlight, dont place laptop near loud speaker keep laptop away from magnet it destroys the laptop discharging of a battery is very essencial take the back up always
keep it always far from dust
on Feb 28, 2010 | Computers & Internet
Dead battery
Check the glove box light,make sure it goes off when closed.
Apr 18, 2014 | 2006 Mazda Tribute
Brake shift interlock switch
Listen to me. Put the jumpers on the car, If you have a second set use them also. Go inside and have a cup of coffee and talk to the Mrs. The point I'm trying to bring out is leave the cables on the car for at least 20-30 minutes. Don't try to start it right away because the cables you have are JUNK as are most jumper cables sold today. Simply give it ample time to charge. Once you get it started, leave it running to further charge the battery.
Apr 04, 2014 | 1999 Mercury Mountaineer
Battery drains, battery replaced, battery dead 2004 ford F150
Seen this "mystery drain" many times. Check spark at the battery to see how big the drain is. For this simple test, blow away any (explosive) battery charging fumes. Leave one terminal on and gently touch the other to its post in fairly dark surroundings. Then try it again with the wires taken off the alternator. Your spark is now probably much less. Usually bad diodes leaking electricity backwards through the alternator cause this drain. Replace the alternator or the diode pack inside it. Some mechanics recommend actually measuring the drain.... hahaha. OK whatever. But the radio memory and computers/control modules are the only things that should cause a drain. Not the alternator.
Jan 28, 2014 | Ford Cars & Trucks
Electrical battery drain OR "parasitic drain"
Dec 27, 2013 | 2008 Subaru Outback
My 1999 saturn sl, everytime i go to start my car its dead, i dont leave my lights on or anything, (battery problem) what kind of battery does this model car have?
well the battery could be refusing to take much of a charge, the alternator might not be putting out enough to keep the car running and charge the battery. or there could be something draining the battery, even with the ignition in off position. you can take the battery and alternator into advance or autozone for a test, but the drain problem is going to take some trouble shooting. things which are on even when off can be the remote door locks, remote starter, lights in the glove box and trunk. if you have aftermarket stuff like custom radios, GPS, etc. are usually put in by someone who does not know what they are doing so i would start there.
Feb 27, 2011 | 1999 Saturn SL
My mercedes sat for 10 months while I recuperated from injuries. The battery was completely dead. Remote didn't even work. We were able to jumpstart it with battery cables but it won't keep running. Dead...
You will burn out your alternator if you keep on doing this.The alternator is not a charger. If you have a dead battery you should always charge it overnight on a charger.To keep the battery fresh all that you have to do is disconnect the terminals.Yes this is normal because the car has clocks and alarms that drain power even when the key is off. If you let the battery set to long while it is drained it will not take a charge.
Jul 06, 2010 | Mercedes-Benz C230 Cars & Trucks
2007 Vue hybrid. 12-volt battery dead? No electric key opening, lights, starting, etc. Can I try to trickle charge it? We;ve been away a week, but it has been sitting in a garage above 50 degrees.
If the battery is completely dead a trickle charge won't do much. These are designed to keep a good battery good. You need a regular battery charger set to 10 amps for a couple hours then 2 amps overnight. Be aware that sometimes if your battery has been completely killed it may not work for long, that is your car will start but within a few days or hours it will leave you stranded. You'll know because it will drag when you try to start it. Sometimes you get lucky and it works great for years.
Next time do use a trickle charger! Also if the charge you use is automatic then you can leave it hooked up in 2 amp mode when you are gone. Good luck!
Mar 26, 2010 | Saturn Vue Hybrid Cars & Trucks
1997 lincoln town car battery drain
Sounds like short ore you leave some dash lights on to drain the unit. If relay start to make you upset die hard made a battire that you could shut off like secuirty thing to shut down the power it cost 150 i dont know they still make it
Jul 28, 2009 | Lincoln Town Car Cars & Trucks
Uniden GMR-1088 2-way Radio Walkie Talkie Dual Pack with NOAA Weather Alerts Logo
109 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
