Question about X-Acto XActo School Pro Electric Pencil Sharpener
Fix a X-Acto Pencil Sharpener 1606 Model
Making a high pitch sound. The blades do not turn and there is nothing stuck in the blades.
Tip
How to sharpen a pencil so the tip doesn't break
When I was in school it would always frustrate me that the tips of the pencil were always breaking in the sharpener. It took many tries of turning the pencil and turning the sharpener, different amounts of pressure and I finally found the secret.
Sharpening a pencil is a very easy thing to do. When you are using a hand sharpener, either a small plastic one with a cartridge to catch the shavings or the really small ones that don't catch the shaving, your put the utencile end of the pencil into the sharpener keeping it has straight as possible.
Applying a little pressure turn the pencil in the clockwise motion (you can turn either the pencil or the sharpener both will work). The shavings will begin to fall off and you keep turning until either you are satisfied with the sharpness of the tip or the shavings stop coming off. Make sure that you don't put more pressure on the pencil to make the shaving keep coming off because that will make the tip break and get stuck in the sharpener.
Pull the pencil out and clean the sharpener, it should be good to go. What I discovered was that if I had dropped a pencil a few times then the lead inside the pencil would be broken and this would cause the tip to break after sharpening. Treating your pencils nicely will keep them from breaking tips when you sharpen.
on Jan 30, 2014 | Office Equipment & Supplies
Pencil sharpener won't stop running
probably a piece of lead stuck on switch. Unplug unit, shine a flashlight into it and see if you see anything other than the sharpening head(s).
Apr 01, 2014 | X-Acto XActo School Pro Electric Pencil...
Crayon is stuck inside pencil sharpener
Hello, I need the model number of the pencil sharpner. You might go to bostitch and call support for help.
Jan 10, 2014 | Stanley Bostitch Electric Pencil Sharpener
What kinds of pencil sharpners are there?
There are many kinds of pencil sharpeners that have been developed through the years.
The most common ones, the manual sharpners, can be of the following kinds:
Mechanical sharpeners: a portable variety, usually small and in the shape of a rectangular prism. The blade inside rotates around the pencil, sharpening it. The shavings emerge through a slot.
Blade sharpeners: small and portable, hold replaceable shaving razor blades or permanently fitted blades. They work similarly to knives, but in a more convenient and safe way.
Cylindrical cutters: larger variety, stationary, powered by a crank. One hand holds the pencil, the other turns the crank.
Another common pencil sharpener found often in offices is the electric sharpener. It works on the same principle as the manual sharpener, but the blade rotates quickly thanks to an electric motor, either powered by batteries or plugged into the electrical system.
There are still people, mainly artists, that sharpen their pencils with a knife.
Oct 06, 2013 | Office Equipment & Supplies
How do I change the blade on a iPoint evolution pencil sharpener?
Have you tried unscrewing the small circle that you insert the pencil into? Once that part comes off the blade should be more exposed.
Jun 10, 2013 | iPoint 15509: Evolution Axis Pencil...
Where can I buy a shavings receptacle replacement for my X-Acto School Pro Electric Pencil Sharpener Model 167X. Mine got dropped and broke.
This is a new answer for an old question. Just today, I emailed the Xacto company (contact us on their website) and they responded with " a courtesy replacement will be sent to the address below."
May 06, 2013 | X-Acto XActo School Pro Electric Pencil...
When I insert a pencil into my brand new school pro sharpener, the blades spin, but do not sharpen.
The website says to check and make sure its not jammed with pencil lead or something else. unplug it take the shavings bin out and flip it upside down so you can look into the sharpeners. Rotate them by hand till you can see the open side of the blade then use a unfolded paper clip and slide it in the path the pencil would usually take. This should knock anything loose the would be jammed in there. If it passes through to where you can see the point you should be clear. If you didn't dislodge anything or it still doesn't sharpen but the blades spin when you try to use the sharpener, then there is a tab that can get jammed back that needs to be in the foreword position. The tab is located where the tip of the pencil would point if it was actually being sharpened. if you run the paper clip through the machine (just like when trying to dislodge something) the tip of the clip will touch the tab. make sure its not jammed back (away from the opening/pencil) it should be as far forward as possible for the blades to engage. I hope this helps! This has been jammed many times by pencil shavings or gunk on my wife's (elementary school teacher) pencil sharpener.
Sep 22, 2011 | X-Acto XActo School Pro Electric Pencil...
Will not start when I press manual button then when I press the auto button, I hear a high pitched screeching sound. Is this a burner motor problem ? What is the fix? Thank You. Laser model 55...
fribue,
I am not an expert but I had a similar situation with my 55. My 55 was only making a droning sound when I turned it on. I contacted the company and they told me it could be excess carbon build up in the exhaust fan.
I accessed the exhaust fan from the back of the heater. I took a pencil with an eraser stuck it in the exhaust port and gently begun to spin the fan using the pencil eraser. After a minute or so the exhaust fan starting moving very freely. Then it worked like a charm
I hope this helps.
Oct 25, 2010 | Rinnai Toyostove Direct Vent Heater:...
X-Acto XActo School Pro Electric Pencil Sharpener Logo
106 people viewed this question
Top X-Acto Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a X-Acto Office Equipment and Supply Expert? Answer questions, earn points and help others
