I have been trying to get my yellowEthernet cable to fit at the rear of my laptop computer without succes . what am I not doing to get connected/
  • 59 Answers
Look at the connector on the back of the laptop does it have 4 or 8 gold pins? You maybe by mistake trying to plug itinto the modem port 4 pins look for a slitly bigger connector lan 8 pins should slide on like a glove.
Posted on Oct 24, 2008
    Master:
  • 409 Answers
Are you saying that the Ethernet cable will not fit in the Ethernet socket?
Usb cable is causing a short circuit
the first cable (throw it away), the secound use that one or a new one. then you will need to locate the drivers on the internet, download them and install.
Jul 20, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
How to connect the cable to my Akai tv set without a cable input? I don't have a cable box.
If you get a cable box that has audio/video outputs on the rear connect them to a identical input on the rear of the set----direct connection and bypasses the coax fitting most sets have.
Go to the input you hooked to and leave set there--change channels via the box with its remote or manual buttons.
May 27, 2012 | Televison & Video
The laptop will not recognize the DVD says it can't formate it for backup it says the recovery is full? The laptop does not connect wirelessly to the internet is this all related?
The dvd driver is bad must be reinstalled. try nero or other but do that you will be happy.
If this solution doesn't correct the problem, right click my computer then manage, then see if there a driver who is miising , reinstall'm
try you will succed
May 09, 2010 | Dell Inspiron 9400 Notebook
Downloading immages ,connecting camera to computer.
I have the same problem! I looked for an answer to this problem on the web, but without results...!!!
Nov 15, 2009 | Canon IXUS 80 IS Digital Camera
Want PC Suit of W700i
sir you can acces data cable without pc suit when you connect your phone to pc in phone it shows two options you just select filet transfer if doesnt succes then you have to change your usb cable
Sep 09, 2009 | Sony Ericsson W700i Cellular Phone
Bd-rom in Acer Aspire 8930G - not working
You could have a faulty DVD/CD drive.
Take it back to the shop as the laptop is under warranty.
Do not try to fix it yourself as it might void your warranty.
May 23, 2009 | Acer Computers & Internet
Toshiba LCD projector
always make all connections first !! after that : switch on the laptop, or else no detection of an external monitor/projection device is possible.
Please check also your bios settings, some can be set to force simultaneous display of external screen and lcd of the laptop.
some laptops also require ddc communication between external connected devices.
Try to use a full wired ( except pin 9) VGA cable.
succes
Aug 31, 2008 | Radio Shack Cinego D-1000 Multimedia...
Right speaker stops working
A couple of years later, but maybe this will be useful to someone:
1. Disconnect the cables (input, power, 2nd speaker).
2. Undo the two screws on the base of the casing.
3. The two knobs can be pulled off. Underneath there are two nuts that hold the spindles to the casing. Undo these.
4. The fabric cover is a push fit. Prise it off the front. If needed, use a (non-metal) tool that won't damage the plastic casing.
5. Under the cover, the two top holes contain screws - undo these.
6. Four screws hold the actual speaker to the casing. The two lower ones are slightly longer and also hold the casing together. Note this for reassembly.
7. You can now gently part the front and rear parts of the speaker housing.
8. To completely separate the parts, you need to disconnect the red and black wires that go the the speaker. The are push fit 'spade' type connectors - a tight fit, but removable.
My problem is similar - loss of left channel. I think the problem is in the headphone socket as wobbling it or inserting non-conducting objects can temporarily restore the channel. These sockets switch off the speaker when you plug in the jack, so I think the switch is faulty. I plan to desolder this part to inspect, repair, replace or bridge the connection and do without the socket.
Hope that helps.
Aug 05, 2008 | Harman Kardon HK19.5 Computer Speakers
Printer non compactability
i bought a hp psc 500 without an installing cd or connecting cable to a Laptop. what can i do
May 22, 2008 | HP PSC 500 All-In-One Printer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
