Question about Hotpoint Washing Machines
Hotpoint ultima error message f08 what does it mean?
  • 409 Answers
F08 actually means the heater relay cannot be activated.
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this.
Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat,give the wires a good tug as they can break internally and look ok.
If you have a multimeter, test the heater, it should read around 25 ohms.
Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle.
Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on.
If everything checks out ok, then it's likely the main control board is at fault.
Posted on Feb 13, 2012
What does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Feb 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
What does the message F-08 mean on my Hotpoint Ultima wt721 please?
Error code F08 that the heater relay cannot be activated.
Check all connections to the module, pressure switch, and heater element.
Hope this helps.
Feb 01, 2010 | Washing Machines
Hotpoint ultima WT965A fault code F08 what do i need to do to fix it please. wachine is full of water and i cant select any cycle to empty it.
To empty the washer, remove the drain hose from the outlet, and lay it down to floor level, this will let the water run out into a bucket or similar.
Code F08 is indicating means heater relay cann ot be activated.
Check all connectios to and from the pressure switch, the module, and the heater.
Hope this helps.
Jan 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
F-08 Error message keeps appearing
Error code F08 indicates that the heater relay cannot be activated.
Check connections on
1--pressure switch.
2--heater element.
3--control module.
If you still cannot get it to work, then you are probably going to have to call an engineer.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F-08
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Hoep this resolves your issue. God Bless.
Jul 09, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ive got a ultima WT965 and it keeps saying F-08?
F08 HEATER RELAY STUCK CHECKPRESSURE SWITCH /HEATER + MODULE CONNETIONS
Mar 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima keeps triping the trip switch. it had f08 on the screen but now that has gone, but still trips electrics every time i press start.
Hi
f08 means heater relay cannot be actived so try unplugging heater element and see if it stops tripping the electrics.
regards
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
F08
your heater relay is stuck check all wiring connections to and from heater
Sep 14, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Washing Machines Logo
202 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
