Question about SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry
Simpletech signature mini 16GB external hard drive - blue and red lights do not turn on
I have a simpletech signature mini 16GB external hard drive and a couple of weeks ago it was experiencing some weird clicking but both the red light and blue light were on and after some delay my files finally appeared. I just tried using today and neither the blue nor red light show up anymore and there is no noise, it seems to be completely dead. is there anyway i can recover my files?? thank you.
  • Melissa Buisan Feb 13, 2012
    oops i mean a 160GB external drive!
  • SimpleTech Master
  • 27,725 Answers
Make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
if you need help obtaining the usb card post a reply
hope this helps
Posted on Feb 14, 2012
WeListen2You
  • 538 Answers
SOURCE: Not detecting
hmmm..what operating system you using..
Posted on Oct 13, 2008
SOURCE: My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Posted on Mar 23, 2009
  • 10 Answers
SOURCE: SimpleTech Signature Mini (320GB) unable to find on my laptop
if you hear a constant clicking return the drive it is faulty.
Posted on Mar 28, 2009
  • 7 Answers
SOURCE: my signature mini hd doesnt work........
With this situation, only a data recovery company can help you. I am afraid that there is some mechanical damage to either the case or the hard drive. If you can remove the case and test the drive, you may be half way there, but if drive is clicking, it is best you leave it to professional data recovery. That is what I do, but you don't have to send it to me. You can bring it to your local shop to see if they can help.
Posted on Jun 19, 2009
bschilz
  • 2049 Answers
SOURCE: I plug my Simpletech Signature Mini hard drive in
When you plug the drive in, Windows should recognize it and make it immediately available for your use.
To confirm this, click Start then Computer and it should show up as a device with removable storage. If you click on the Signature drive, you will see the contents of the drive and you can use it just as ou would your "C:" drive.
Posted on Sep 05, 2009
I need a manual for the black cherry portable high-speed UB 2.0 hard drive. The one I have is 160 GB. Thanks.
Here is the manual that covers all of the SimpleTech Signature Mini External USB 2.0 Hard Drives. This is a pdf document, so you may need to install Adobe Acrobat Reader if you don't already have it installed.
Hard Drive Manual
Regards,
Dan
Mar 05, 2011 | SimpleTech Signature Mini 320GB External...
I dropped my drive and now the computer won't recognize it. The blue light is on with the red light. Help!
Sorry to hear that your drive is having trouble. When you start the drive, do you hear it turning?
Is this a external that you can remove the hard drive? You may try to power down the external, power it back up and shut down your computer. The conect the external and turn the computer on.
Let me know if you can hear the driver turning and it you can connect after going thru the process above.
Brian
Feb 05, 2011 | SimpleTech Signature Mini 320GB External...
I plug my Simpletech Signature Mini hard drive in but than I don't know what to do from there.
Sep 05, 2009 | SimpleTech Signature Mini 160GB External...
Simpletech Signature Mini not reading
It is easy, just conect it to the motherboard as a slave disc
Sep 04, 2009 | SimpleTech Signature Mini 320GB External...
I have a 160GB signature mini external harddrive. It has been working fine for months but all of a sudden my laptop won't recognize when I plug it into the usb port. The red light comes on to show that it...
It sounds like your hard drive is dead. If you have tried it on a different computer and it did the same thing then your drive isn't booting up and is probably bad.
Aug 09, 2009 | SimpleTech Signature Mini 160GB External...
Mar 27, 2009 | SimpleTech Signature Mini 320GB External...
SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry Logo
117 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
