Question about Nintendo DS Lite Console
My Nintendo DS Lite does not charge (but turn on) and the clock has stopped.
Hello, guys! I am having a big problems with my NDSL. Problem nº 1: My DS Lite does not charge. The charge's light turn on but in the system not consider it is charging. I have 2 batteries and both work perfectly (I tested with a multimeter). Other strange problem is when I am in the system with a NDS card inserted with low battery the light is red (normal) but if I remove the card the light goes green O__o. I thought it was a problem with the component EM10 filter but I tested it and it is ok. Problem nº 2: The NDSL clock has stopped. Not moving. Remove and replace the battery don't solve. If you didn't realize I need to change the battery all the time to play (I have an external battery charge). OBS: - I have 3 or more chargers and all are working perfectly. - I have 2 batteries and both are ok. - NDSL didn't fall down or wet. - I don't live in USA ( you can see my bad english) and my city doesn't have a technical support for the console. Answers with the Nintendo Call Support or send my console to repair are useless, unfortunately. Thanks for your patience.
4 Suggested Answers
nliwilson
  • 114 Answers
SOURCE: NDS or NDSL R4
Although there are some "home-brew" games and software out there this type of cartridge is largely used for illegally copying games. Some of the software available includes MP3 playback programs, movie players and PDA software so you can make use of these cartridges for legitimate purposes, however "home-brew" games vary in quality and so called ROM files are normally illegal copies of games/software that are subject to copyright licensing law.
Posted on Aug 09, 2007
SOURCE: Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Posted on Nov 30, 2007
  • 152 Answers
SOURCE: nintendo ds lite
Try opening the system up and cleaning it out.
Posted on Dec 24, 2007
Orange screen
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Here you go here's the instruction on how to repair your problem with DS-L.
http://howtorepair.info/408/how-to-repair-a-nintendo-ds-lite-ndsl-bottom-screen-1/
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 08, 2011 | Nintendo DS Lite
Nintendo DS lite- N card
Your DSL files which you have deletd might be some system files containing in it. Please restore the files so your DSL works properly. You also have to replace the same files on your second Ncard to make it work.
May 16, 2010 | Nintendo DS Lite Console
My ds lite has stopped charging. we bought a new
theres problly internal problem! maybe some cable connection inside the system is not working!
Apr 08, 2010 | Nintendo DS Lite Console
My nintedo ds will not turn on
Most probably your battery ain't working no more. Most probably u dropped ur NDSL and it damaged it. But sa its under warranty why do u take tension? throw it up nintendo, they'll replace it for free.
Mar 24, 2009 | Nintendo DS Lite Console
Ncard for NDSL
Make sure the DS is turned on while doing this. It may need to be turned on to be recognized by your PC.
Thanks - Tech101
Jun 23, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Ds lite
nope no card needed , if you see on the bottom of your NDSL(nintendo ds lite) youll see a thing u pull out (or there might not be one) and you put the games in there
Nov 27, 2007 | Nintendo DS Lite Console
Nintendo DS Lite shuts down after holding down B-button
mm i dont know but go to nintendo.com and they have a place on the website 4 problams 4 nintendo products or get a new ds / ds lite google might help to
Oct 17, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
82 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
