Question about Refrigerators
Replace caravan fridge element - Refrigerators
  • anthony weyer Feb 18, 2012
    our element has gone in our caravan fridge. i have bought a new one which is correct for the size and model but, i need to know how to take out the old one and input the new one. the fridge is a dometic make. can you help?
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
Caravan fridge
See if you have access to a schematic on the unit itself. The fact that it works fine on gas tells you there is nothing wrong with the ammonia solution in the tubing. For that unit to work, the electric heating element has to boil off the ammonia and this is not happening. Check on the schematic if there is some kind of fuse or additional in line switch which is preventing the heating element from turning on and doings its job.
Nov 27, 2013 | Refrigerators
Why does my caravan fridge trip out when connected to 240v
The heater element is almost certainly to earth. Work it on gas until you can fit a new heater.
Jul 01, 2012 | Refrigerators
RM6270 in a touring caravan, over 5 yrs old. Worked fine until mid-Sept, when it ceased on 240V, 12V & gas still good. Any other sources of the problem possible, other than the 240V element (e.g. power...
Some of the Dometics have what was called the 'Dinosaur Board' which is a circuit card which controls the unit.
http://www.dinosaurelectronics.com/
Not sure if it applies to your exact model, but if there is a company who just makes replacement control boards for Dometic fridges, that is a big fat clue, in my book. Cheers.
Oct 21, 2009 | Dometic RM2652 Refrigerator
I have a Thetford N112 which will not cool the
un plug the heating element from the circuit board and ohm it out. also check fuse on board. but sounds like the heating element has gone out. if when you ohm it its on 0 its bad
Aug 27, 2009 | Refrigerators
Open air filter box to replace filter on a 2000 dodge caravan
the filter element is actually below the box that says air filter element. You remove it from air intake and disconnect from frame and element case. The element is in a black box behind drivers side headlight, facing sideways. Its a pain, but working on this particular engine is rough. They designed it to be worked on at a shop with specialized tools. Average wrenches and sockets don't have enough room to turn! Since this element is hard to replace, you'll notice a marked improvement after changing this bad boy/
May 24, 2009 | 2000 Dodge Caravan
My caravan fridge was working on 12v last time out but now it is not
Check to see if the heating element is getting voltage if it is chances are the element is bad
Aug 19, 2008 | Refrigerators
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
