Question about Acer Computers & Internet
Screen is dark
With a flashlight i can see the screen
  • 400 Answers
Hello
This is either a problem with the screens internal lamp or inverter.
The defective part needs to be replaced and can only be replaced by a computer technician or someone with similar experience.
hope this helps.
Posted on Feb 13, 2012
Sanyo Dp19649 screen wont stay on, just sound. when i look close with a flashlight i can see the static from static channel it on. what i do?
Back-light inverter fault. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 28, 2014 | JVC LT-32X576 32 in. LCD Television
K53e asus has dark screen how do i find and replace the backlight?
The CCFL lamp is located at the bottom of the LCD screen behind the plastic bezel in between the hinges.
You maybe able to get a CCFL lamp from this WEB site.
LCD screens and Inverters www.lcdparts.net
Feb 12, 2013 | ASUS Computers & Internet
Toshiba 37xv555db no picture
Its a LCD set--try in a dark room (very dark) to shine a small flashlight at the screen with set on-------------do you see a very faint image or picture on the screen?
Oct 29, 2012 | Toshiba Televison & Video
Screen keeps t going blank but still have power
It may be the internal backlight that is failing. When the display has failed but still has power, take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 24, 2011 | Xerox XG-91D 19" LCD Monitor
My proview 19 in turn on but then it goes black is it a capasitor and how to fix it or is ther a reset on it
It may be the internal backlight that is failing. You can take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Mar 22, 2011 | Proview PL926WBi 19" LCD Monitor
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
4gb nano apple icon flashing on dark screen
try connecting it to the iTunes program and resetting everything
Jan 25, 2009 | Apple iPod nano
Computers & Internet Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
