Can i use sling adapter for Dishnetwork VIP-222k
3 Suggested Answers
  • 132 Answers
SOURCE: Need RCA TV code for Dish Sat reciver Vip 222K D
SEE IF YOU CAN FIND THEM AT tvcodes.com
Posted on Nov 14, 2009
SOURCE: why wont my vip 722
Hi ormsethkellymy name is Mike Houston of DISH Network and I was going over your post andwanted to check something's with your receiver. If you're watching a programand do not touch the remote and you see the receiver go off you can disable theInactivity Standby, you will want to push the buttons of MENU-8-8 and make sureit is disabled and you will be able to watch a program without the receiverturning off.
Posted on Feb 13, 2011
I have no signal,what can I check?
OK Joan,, I might need more info. not getting signal could be caused from several things.. one make sure the Dish Antenna is mounted correctly, (level, and true, [one degree off on earth is like 700 miles off at the Satellite.]) check you cables and make sure they is now wire touching the center core of the coax. if the coax has splitters, connections etc outside check for the corrosion inside the threads.
make sure the coax coming into the house is connected to the right place on back of the 222k. make sure u are on the right Video stream for the HDMI. are u getting any picture showing the Dish set up or is the screen all Blue.. if it is blue try to use the remote that came with ur TV (RCA, Vizio, Phillips,,,,etc) and look for the input, source , or Antenna button and push it to match your HDMI input..
Oct 28, 2014 | DISH Network Vip 222k Hdtv Satellite...
Dish network receiver model 512 switch test says I am getting fewer sattelites than previously detected
were you getting all the Satellites before? could be Tree limbs in the way (very very common) could be the Dish had moved.. rotten boards, etc make sure the dish is mounted solid. could be the LNB gone bad. or coax has corrosion etc, many things can cause it. but usually a easy fix..
Jun 08, 2014 | DISH Network Vip 222k Hdtv Satellite...
I am trying to readdress remote tv2 21.0 IR/UFH PRO but to receiver DISH network VIP 222k. we have tried every way and it always switches remote address tv1. we tried all the steps from the handbook b
Hello, German Quinchia!
I would be happy to provide assistance on this. It sounds like the remote itself may need to be setup correctly. Since this is going to be the second TV, on the bottom of the remote, make sure there is a blue 2 at the bottom instead of a green 1. Once you have the blue 2 showing, try addressing the remote again.
If the problem persists, remove the battery cover. Inside will be a switch. Make sure the switch is toggled to UHF rather than IR. Let me know here if the problem still continues after that.
Tommy Faust
DISH Social Media Representative
Feb 12, 2013 | DISH Network Televison & Video
Dish network 222
Sounds like power supply problems, mak sure plug goes directly on a good tight wall scocet for full 120 volts and enought amperage to run your unit, to many devices may drain your power.
Nov 10, 2012 | DISH Network Vip 222k Hdtv Satellite...
I'm trying to connect my slingbox connection to my dishnetwork box. It is currently connected to my modem and all lights are on. I changed my modem since getting my slingbox, so my security info has c
Hi Linda,
Here are somethings to try. You should not have this problem if you have cable internet. If you have DSL service make sure the modem is in bridge mode, next make sure the settings are MTU enabled and finally place your setting to 1492. If you need further assistance please email with all information on yor set up and the DISH Network account number.
Thank You
Mark Haakenson
Internet Response Team
DISH Network LLC
mark.haakenson@dishnetwork.com
Nov 20, 2011 | Sling Media SL150-100 Network Adapter
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
CANT GET ON LINE
The ethernet port is not active on these receivers thus not allowing you to get on ine. There currently are no plans to activate this in the future but you may for an upgrade to a 722 which does allow this and is HD capable and has 300 hours of SD record tine available. Thanks for using Fix Ya.
Feb 14, 2010 | DISH Network DVR-625 DTV Receiver /...
Problems with dish network remote
Hi dsmcfarland there are acouple of things you can do so the remote works better. On the receiver selectthe System Info button, it will take you to the System Info screen, at thebottom you will see two white boxes the first saying "primary remote address"and "secondary remote address". With the TV1 remote press and release the SATbutton and press Record button one time. You will see the primary addresschange and then press Select button on the remote. I will send a link to helpout with these steps. http://www.dishnetwork.com/SupportSection/remote-control
Jun 20, 2009 | DISH Network ViP 211 DTV Receiver
Televison & Video Logo
494 people viewed this question
Top Televison & Video Experts
Electro Med Services...
