Question about Sony Video Game Consoles & Games
Ps3 serial number cg918336772-cech-2501B - Sony Video Game Consoles & Games
What is the gig for this ps3 serial number aa259333942-cech-4001c
I did a search and all the cech-4001c models I could find where all 500gb so its a good bet that is what you have
to be sure you should try and check, To check Go into the 'Settings' on the PS3 Menu, then into 'System Settings' Then scroll all the way down near the bottom to 'System Information' Enter it and you will see the ps3 info including how much space is on the Hard Drive
Nov 04, 2015 | Video Game Consoles & Games
Tip
How to fix your PS3 when it's frozen at startup
1.The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
2.Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
3.Time to enter Safe Mode.Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
4.Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
5.Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
6.Select option number 3, (Restore File System). Then select yes to perform step.
7.You will then see this screen. "The hard disk's file system is corrupt and will be restored."
8.First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
Tip
Fix PS3 "Corrupt Hard Disk"
Connect controller to PS3 screen. You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen. You will then see this screen. Safe Mode options screen
-REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
on Feb 20, 2010 | Video Game Consoles & Games
I live in South Africa and bought a PS3 Baseball game. It works in my PS2 but not in the PS3, because of the zone code. What is the correct zone code
I assume you bought a PS2 game that works on your PS2 system but not on your PS3 system since a PS3 game will never work on a PS2.
Since not all PS3 systems can play PS2 games, you need to first check the model number of your PS3 system. If you look at the back of your PS3, there should be a serial number somewhere that starts with "CECH", followed by one more letter and a couple numbers (e.g. "CECHC02"). Unless the model number starts with "CECHA", "CECHB", "CECHC", or "CECHE", you won't be able to play PS2 games on your PS3.
If your PS3 can play PS2 games, then you need to make sure that the region of the PS2 game matches the region of your PS3. The region of the PS2 game can be found in the upper-right corner of the front of the box the game came in. The four regions are: "NTSC U/C", "NTSC J", "NTSC C", and "PAL".
Once you know the model number of the PS3 and the region of the PS2 game, you can tell if the PS2 game should work on the PS3. Use the following chart to determine if your game and system are compatible:
Last two digits of your PS3 model number: Playable PS2 game region
00: NTSC J
01: NTSC U/C
02: PAL
03: PAL
04: PAL
05: NTSC J
06: NTSC J
07: NTSC J
08: PAL
09: NTSC C
11: NTSC U/C
12: NTSC J
Apr 29, 2012 | Sony Playstation 3 (PS3) Console
Tip
How to fix your PS3 when the hard drive disk is corrupt.
Connect controller to PS3 screen. You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. You will then see this screen.
You will then see a screen. "The hard disk's file system is corrupt and will be restored."
on Feb 14, 2010 | Video Game Consoles & Games
How to fix a corupted hard disk for a sony ps3 ?
  • Put your PS3 in Standby Mode.
  • For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
  • Time to enter Safe Mode.
  • Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
  • Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
  • REMINDER: - BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
  • You will then see this screen. "The hard disk's file system is corrupt and will be restored."
  • The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Good Luck and have a nice day.
Thanks for using Fixya
Jun 09, 2010 | Sony Playstation 3 (PS3) Console
Ps3 on screen is saying hard disk is corrupted
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
I wish you good luck.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Ps 3 wont load games cd or dvd
Hi mate
Call sony in this case as long as you do not open your console yet. before speak to them tell then that your ps3 is no longer reading discs they have been know to repair it for free.
It the laser gone most probably the KEM400aaa you can tell by the CECH**** code on the end of the serial number
If they will not repair for free it will be a cost of £99.00 or you can repair your self by replaceing the laser around £65.00
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
While playing games my ps3 locks up in the middle of the game
I am afarid that your laser is failing in you PS3 you can insert a lens cleaner to make sure it is not dust on the lens.
You may have to replace your laser in the near future you can find what laser you will need by the CECH*** number on the end of your serial number I expect is the KEM400a which is the older laser which has faults
If it is unber warrentee then that the way to go and if you want you can call sony to see if they will repair for free but if not it will be £99.00
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
