Question about Dell POWEREDGE R610 (4640223) Server
Install a sound card on Dell PowerEdge R610 server?
Hi, I need to install a compatible sound card on the above server. Spoke to Dell and as expected, they done support any sound cards on the server. Can somebody please help me here. Thanks
  • Venkatesh Kulkarni Mar 06, 2012
    kindly clarity me your server hardware specs and sound card details
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
Posted on Dec 09, 2007
  • 7 Answers
SOURCE: dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Posted on Mar 17, 2008
  • 13433 Answers
SOURCE: Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Posted on Jun 07, 2009
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Posted on Jun 11, 2009
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
Windows server 2008 drivers for celsius r610?
That system has support for windows XP and Linux (RedHat and SuSE) so if you want to install windows server 2008 you will need windows 2008 compatible drivers, maybe this link bellow can help you to identify right drivers (It is detailed technical motherboard manual for that system)
Manual
Mar 15, 2013 | Fujitsu Siemens Celsius R610 PC Desktop
Install Dell R610 with windows 2003 server
For the ISO - https://www.microsoft.com/en-us/download/details.aspx?id=21700
Burn it to a DVD or use "Rufus" for a flash drive. Make sure you have a good key code.
Nov 27, 2012 | Dell POWEREDGE R610 (4640223) Server
Hi, my Dell PowerEdge 1850 Server freeze at boot screen after print remote access controller detected. anyone ve any solution on it ?
I had exactly the same issue, its basically your iDrac card thats likely at fault. I simply removed mine and the server would boot as expected. If you require the iDrac then order a new card and this should solve your issue.
Feb 18, 2011 | Dell PowerEdge 1850 (PE1850) Server
How or where in the BIOS do I switch video source to PCI? Old Dell PowerEdge 600SC. Attempting to install new video board.
Most servers (including the 600SC) were not designed for use with add-in video cards, thus, there is no jumpers or BIOS setting to disable the onboard video.
Mar 13, 2010 | Dell PowerEdge 600SC (Refurbished)...
Dell poweredge 2300
Servers usually don't come with sound cards. If you really need one, you must install one. If it is truly a server, I would recommend against it.
Apr 11, 2009 | Dell PowerEdge 2300 Server
No Sound !
did you installed sound driver...if not then install it then sounds will come
Apr 11, 2009 | Dell PowerEdge 500SC Server
NO Audio out put
dell2_bing.gifpoweredge servers are not needed for sound. DELL support will notsupport any sound cards or care anything about your audio issues. Youwill not find audio drivers because again, a server's purpose has nothing to do with audio.
Jan 27, 2009 | Dell PowerEdge 600SC (Refurbished)...
Ethernet adaptor
Hi
The embedded NIC is Intel 82559 10/100 Ethernet controller. You may however install a Gigabit NIC as a PCI card.
Mike
Jul 23, 2008 | Dell PowerEdge 4400 Server
Dell POWEREDGE R610 (4640223) Server Logo
355 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
