Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS tape won't eject
How to remove my VHS video tape it won't eject and just shut down?
    Top Expert:
  • Philips Master
  • 74,459 Answers
Hello
Check for any borken drive belt in the mechanism.
Posted on Feb 14, 2012
  • cfarrice660
    cfarrice660 Feb 14, 2012
    how do I check for a broken drive belt on my vcr?
  • The Knight
    The Knight Feb 15, 2012
    You have to open the VCR and look into its mechanism. Without any knoledge about the working of the VCR, you never can do this by yoursef.
    Problem Solver:
  • 34 Answers
You can choose something you need from the web http://www.mubuy.com/electronics/
Posted on Dec 02, 2013
  • 15 Answers
SOURCE: vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
Posted on May 13, 2007
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
Demonic-2011
  • 467 Answers
SOURCE: The vcr won't automatically accept
Probably a corroded or dirty mode switch, or a mechanical fault, which will require workshop attention by a qualified service technician. You can submit your unit for a quote, and a second opinion (on the nature of the problems and costs involved) then you can make a decision to go ahead or not. Up to you, but unless you have experience, lots of equipment and tools, an understanding of service manuals and diagrams, know what parts are needed, and how to replace them, this is a job for a licenced technician, as there may be mechanical alignment procedures to the VCR as well as repair.
They may even have to replace the entire VCR carriage assembly, since forcing tapes etc., may have caused some minor damage. No doubt they will tell you this if warranted. As I said, get a quote, then you will know for sure what you're up against in terms of repair/service charges. If the overall cost is likely to be more than the price of a new unit, cut your losses, and simply buy a new unit (or just a standalone VCR), and keep the Magnavox as a DVD player (if that part still works OK). Ebay has heaps of VCRs available, new and used.
However, if it turns out to be just a faulty mode switch, and no other damage or faults are found, it could be a simple repair - but be warned - labour charges via a service workshop can be costly, hence the suggestion to buy a new unit, if needed.
Many service centres charge a fortune just to look at it and tell you what is wrong with it. The decision is yours.
Posted on Jul 13, 2011
Ironfist109
  • 3018 Answers
SOURCE: My philips dvd/vcr recorder
  • Hi, i can help.
  • A couple things could be going on here. One thing is it could be very very dirty and need a good cleaning. Use a cleaning tape or open it and clean the head with a sating cloth and head cleaner. Never use Q-Tips. If you use a VCR head cleaner I would run it through several times.
  • Another thing is your VCR could be having break failure. If the supply hub has brake that is not releasing when it should then the VCR things that the tape is at the end and tries to rewind.
  • Sometimes a tape can be wound a bit to tight and a few taps on both flat sides will loosen the tape up.
  • Can be the belt drive of the gears stripped inside the VCR as well.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Sep 11, 2011
1chinatown
  • 67 Answers
SOURCE: Can hear audio when playing vhs tapes but
Once again, scroll through the video settings on the tv....it should show up.
Posted on Dec 05, 2011
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Does not eject
Best to get the service manual, this will explain the best way to get the tape out of the machine without causing further damage to the drive system.
However if you can't find it, take the top off and remove the tape very carefully. Try and determine how the tape can be removed without force, possibly by moving the mechanism by hand.
The video shuts down to prevent the problem causing further damage.
Feb 04, 2014 | Fisher FVH-4913A VHS VCR
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
My VHS tape is stuck and won't eject or plsy
The transport mechanism ff/rewinds and drives the tape back into the cassette when eject is used.
Most likely a bad belt or the drive idler wheel (rubber or geared). Unit would have to be taken apart to "see" what is not happening.
Oct 22, 2012 | Televison & Video
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have a ION VCR2PC and the power button won't stop blinking. Also when I put a VHS tape in, it turns itself on and then right off again and ejects my tape. There is not anything stuck in the ION...
If the take up spool is not turning properly it is not uncommon for the machine to eject the tape and turn off. Check the drive to that spool and correct.
Sep 08, 2017 | ION Audio VCR2PC VHS VCR
My VHS tape won't eject, no matter what I do
Take the top of the case off, then you can remove the tape, manually; after you shut down and removed from the powerline.. Maganavox has tape take up problems, which it needs to power on to eject, after auto shut down.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
535 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
