Question about Canon imageRUNNER 2870 Copier
E000225-0001 when start the xerox the machine show E000225-0001
  • Saroj Pati
    Saroj Pati May 09, 2012
    when start the canon 2870 machine,The machine show E000225-0001
I have a problem of fuser module (r3) temperature error in xerox workcentre 5755
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Sep 15, 2016 | Xerox Office Equipment & Supplies
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Cannot get new cyan toner for 7435 to be recognized.. may of been changed before asked for by machine... not sure what to do next
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
May 23, 2014 | Xerox Workcentre 7435 Color Multifunction...
How to fix n9 error on xerox 5020 machine
There are two options because there are two different machine.
One WC5020 with platen or adf and another machine with dadf.
N9 error code has nothing to do with the fuser. You must look for the entire error code n9.xx.
Apr 22, 2014 | Xerox Office Equipment & Supplies
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Xerox majestik 5765 error codes
Sorry I am not familiar with this machine, usually if you press the start key for 3 sec it should show you the other codes? Good luck.
P.S.: If i run into anything I'll send it to you .
Jan 12, 2009 | Xerox DocuColor 12 Color Copier
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Canon imageRUNNER 2870 Copier Logo
263 people viewed this question
old marine
old marine
