No cold water when selected on the temperature setting
Model number LSR8244EQO
  • 98 Answers
Make sure the gas is field
Posted on Feb 13, 2012
catriver
  • 878 Answers
SOURCE: Water temperature problem
Chief Walley, you have a temperature control board that sits right behind the timer. A thermistor senses the water and sends the info to this board. The thermistor sits at the water injector. The board may be your problem, I have seen many like this. Keep in mind that the target temp for cold is 75 degrees. If your incomming water is higher than this, you are going to get a warm fill, which they think is cold. Without being there, I would go after the board. Catriver...post back.
Posted on Aug 09, 2006
SOURCE: Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Posted on Nov 19, 2008
aasc
  • 1606 Answers
SOURCE: automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Posted on Aug 20, 2009
hiltonjug
  • 612 Answers
SOURCE: Water setting temperatures are off
It would say that it should be under warranty.But this model has parts that are no longer availible. Here is my guess, you have a bad switch.
Part number PS1491292
on this web site http://www.partselect.com/
Please rate solution
Posted on Aug 24, 2009
SOURCE: Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Posted on Sep 12, 2010
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Does the hotpoint model 9534 have a heating element in it to heat up the water if the temperature of the incoming hot water is not high enough for the set wash? Because when it only has cold water going...
yes it has an element. first thing is to make sure you dont have the "econmy" button selected as if you do this causes the machine to skip the heating stage.
if not its an element you need part number 1601318.
remove the front facia and panel and you will find the element in the front of the drum
Jul 11, 2011 | Washing Machines
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I can't set my Neptune washer temperature to cold water wash. I press the HAND WASH button which originally used cold water but now it stays on hot water (highest temperature setting). the arrows where you...
you need to call your parts store or the factory number in your book,give the model and serial number to them and order the console,the touch pad is damaged and they sell you the whole top console on the washer
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Aug 24, 2009 | Whirlpool LTE6234D Top Load Stacked...
Maytag washer
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
When on hot water selection no hot water comes out
This an indication that the hot water solenoid in the water inlet valve has failed. If you replace the valve, I bet your problems go away. The following link provides you with step-by-step instructions on how to replace one:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Please post back with your COMPLETE model number (located along the wash tub opening under the washer lid) if you require parts assistance. I can help you locate them online, or provide you with the a part number. I hope this helps you.
Jul 02, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
