Question about Indesit W 123 Front Load Washer
My indesit WIA 111 machine door is jammed with clothes inside. I have tried repeating the cycle but automatic catch doesnt undo. How should I release the door?
5 Suggested Answers
SOURCE: indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Posted on Dec 26, 2009
  • 86 Answers
SOURCE: hAVE JUST AQUIRED WIA 111 without hand book. How
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not sure what you mean by ‘turn off lock’. If you mean the door lock light is on or flashing this may indicate a fault, in which case you would have other lights flashing as well to indicate what the fault is. Click on this link for Hotpoint, Creda and Indesit error code definitions or if you need a free user hand book then click on user manual and select your manufacturer.
Posted on Mar 06, 2010
  • 6277 Answers
SOURCE: WIA 111 stuck on spin
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 21, 2011
  • 6277 Answers
SOURCE: Hi, I've an Indesit WIA 111
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Jul 27, 2011
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
My indesit WIB111 is full of water & clothes. how can I manually drain the water out?
put the machine in the emergency drain mode press the start button when it stops
http://www.manualslib.com/manual/76755/Indesit-Wib-111.html?page=13#manual
Dec 12, 2014 | Indesit Washing Machines
Hi, I've an Indesit WIA 111 Washing Machine, all thats happening is that the door locks and the door lock warning light continues flashing. I've cleaned waste pipe and removed the back to check...
John C
Jul 27, 2011 | Indesit Washing Machines
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
WIA 111 stuck on spin cycle can't reset it, need help! cheers BB
John C
Apr 21, 2011 | Indesit WA 115 Front Load Washer
HAVE JUST AQUIRED WIA 111 without hand book. How
Mar 06, 2010 | Indesit Washing Machines
Indesit WIA 121 not working - door latch not shutting
Oct 05, 2009 | Indesit W 123 Front Load Washer
Indesit wia 121 door lock keeps flashing and when put machine on it goes to a wash without turning dial to correct wash no.
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Jul 28, 2008 | Indesit Washing Machines
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Jul 24, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
