Question about Proform Exercise & Fitness
Proform 831 threadmill
Both motors have stopped running Belt & Elevation. Red Light on both circuit boads. Control Panel display all lit up shuts down when key pulled.
    Top Expert:
  • Proform Master
  • 12,223 Answers
Dear Sir:
You have a serious problem:
Do the following step:
1) Test the power from outlet wall.
2) Test it for ground in the outlet wall.
3)power cord test for loose cable.
4) Reset c.breaker from the treadmill
5)test the transformer for voltage input and output(primary and secondary ).
6)Power supply see if there are some component burn or loose wire or melt.
7)See if there are +5 Vdc for digital circuit(main motor board.(
8) Run the calibration software under the Hood motor is the instruction. for diagnose.
attached the block diagram.
sincerely.
ernesto cuadra
managua, nicaragua c.a.
Posted on Feb 15, 2012
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I need a manuel for my ProForm 620
Go to iconservice.com click on manual then manufacturer the this M# PETL6201
Posted on Jun 28, 2010
SOURCE: I have an Proform 765
HAVE YOU TRIED TO CONTACT PROFORM DIRECT. SOMETIMES THEY CAN HELP OVER THE PHONE. GOOGLE THEM
Posted on Sep 26, 2010
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Proform xp threadmill immediately shuts down and flips the breaker
see the video and LUBE, this happen because the lack of maintenance schedule of lube.However if the problem persist after you did lube, see my persosnal TIPS for motor helps, and test it. a) main motor b) control board. c)old board deck too.God bless you8eec0b2b-b4e5-480b-a21f-11224625d652.jpg7ee45112-69c5-41ab-86a0-1794a9d3376d.gif
Mar 27, 2013 | Proform Exercise & Fitness
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
Initial calibration keeps failing. the treadmill will not elivate
Step 1:
please see this test and fix it. God bless you
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in).
Step 2:
LED.
This the board LED, who control the DC to +12vdc) then the +12V LED lights.
LED.
operating properly.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Step 3:
please lube the elevation motor, shaft, and gear, and adjust the POT for RPM, and see what happen. see the diagram + block diagram attached for troubleshooting and fix it.
God bless you
Jan 07, 2013 | Vision Fitness T9550 Folding Treadmill
Where can I get a motor control board for FN-10282 tredmill
1) please LUBE the DECK belt, the problem from shut down is for to protect the electronic system, this happen because the lack of maintenance schedule. do it
2) LUBE TOO vey well the rollers bearing.
3) if after you do the before steps and the problem remain.
4) test the input voltage motor, if there are the motor is faulty, see mi PERSONAL TIPS.
5) TEST the output voltage boad, for input voltage motor, if there are NOT the board is faulty. see the block diagram
so you can if the board or the motor to www.treadmilldoctor.com
God bless you
Sep 21, 2012 | Proform Performance 400 Treadmill Exercise...
I have a proform 650 v threadmil, and the left side of the buttons panel (start button and incline levels) don't work. could someone help me?
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
Jun 19, 2012 | Proform Exercise & Fitness
My profrom 480e threadmill is tripping as soon as I start it.The kids palyed with red stop button. I put the stop button back, but still it trips.How do i fix it.
Hi
Looseness or discolorations of the prongs on the plug or the terminals in the wall or extension indicate a weak connection. A weak connection lowers the voltage to the treadmill and causes the motor to work harder. With low voltage the motor draws more amperage and causes the circuit breaker in the treadmill to trip.
Another cause for circuit breakers to trip is the belt needs lubrication. Check for belt lubrication and ease of movement. To test the walking belt lubrication, do not turn the treadmill motor on. Set the elevation to the highest level. Stand near the front of the walking belt. Push yourself firmly toward the rear of the treadmill. If the belt is properly lubricated the belt will take you to the rear edge of the treadmill and dump you off on the floor. If you move and stop, the belt needs lubricating.
Also check this related link:-
http://www.livestrong.com/article/404896-my-proform-treadmill-wont-start/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 05, 2011 | Sport & Outdoor - Others
Treadmill shuts down and trip off the power outlet when you change the speed
outlet-breaker may be to lower for machine and or may be other things on same circuit lamps,refrigerator,fans etc try a different outlet with nothing else on circuit and at-lest 20 amp breaker ---if power is good than motor in threadmill might need servicing oil or adjustment
Jan 25, 2010 | Proform Crosswalk 500 Treadmill
Treadmill powers up begins to turn belt then shuts down
Did the shop only do a continuity check or a real load test with amp check also? Motors can look good and run with no load but fail under load.
Mar 25, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
136 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
