Question about Danby DWC310BL Wine Cooler
The wine cooler sounds like a dying cow - we suspect it is the compressor but have been told that it is not worth fixing if it is. Does this mean that it costs more than it is worth to fix it? Is there another problem it could be?
SOURCE: Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Posted on Jul 22, 2008
  • 340 Answers
SOURCE: wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Posted on Jun 17, 2009
  • 1218 Answers
SOURCE: we have a danby dwc283bls wine cooler that no
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Posted on Apr 15, 2010
  • 99 Answers
SOURCE: The Danby wine cooler Model
Sounds like the unit may have lost the refrigeration charge and or there is a problem with the compressor. Check your warranty depending how long you have own the unit it may be covered.
A manual can be downloaded from the following site.
http://www.retrevo.com/support/Danby-DWC283-Refrigerators-manual/id/886ag725/t/2/
Jim...if this information helped you please leave a comment...Thanks!
Posted on Feb 13, 2011
  • 132 Answers
SOURCE: The fan on our Danby
You will need a new fan motor.
A technician can fix that for about $250
Posted on Mar 25, 2011
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
My Haier Wine Cooler HVFM30A the compressor or motor over heated and stop working. Can I replace it?
A new compressor for that unit from Sears parts direct costs $206.
The unit itself is worth around $233 and is no longer in production.
After you pay someone to replace the compressor you'll have spent way more than it is worth.
Your best bet is to get a new wine cooler.
TickMagnet
Aug 20, 2011 | Haier HVFM30A Wine Cooler
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
My ewave made by magic chef model mcwc 30 mcg wine cooler is 5 years old, it just stopped working. Is it worth fixing or spend over $300 to buy a new one?
it could be the ptc relay.to the left of the compressor.if its clicking its the problem.around $27.00 fix at repairclinic.com..part #1206838 the part is behind the plastic cover with 1 screw left of comp.the top part with 1 wire will wiggle off to the left.
Mar 11, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a magic chef wine cooler model mcwc16mcg justs keeping clicking not cold anymore , can this be fixed
A clicking sound every few minutes usually means the compressor is going off on overload when trying to start. This could mean the start parts are bad, or the compressor went bad.
Nov 22, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Compressor for haier bc112g
Dear friend,
ngfam at you service! happy to assist!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Haier BC112G Wine Cooler
Danby DWC310BL Wine Cooler Logo
54 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
