Question about Stihl Garden
Stihl torque settings for cylinder head bolts
Need to know the bolt torque settings for stihl chain saw
emissionwiz
  • 76630 Answers
SOURCE: 2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Posted on Sep 08, 2008
SOURCE: Angle Torque settings head bolts
Use new bolts, tighten in the following stages 1. 20Nm 2. 100Nm 3. wait 3 mins 4. slacken bolts 1&2 retighten to 20Nm +110 degrees 5. carry out stage 4 for bolts 3,4,5 & 6 then bolts 7,8,9 &10 Sequence, 8 4 1 5 9 7 3 2 6 10 Bolts 9 & 10 are flywheel side of the engine.
Posted on Mar 17, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 8 Answers
SOURCE: need cylinder head bolts torque settings for nissan 3.2d
what nissan model do you need the head torques for
Posted on May 01, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
What is the correct torque setting for the cylinder bolts on a Husqvarna 576 chainsaw?
Never worried about torque setings on any of the saw's just get them good and tight.
Sep 14, 2014 | Husqvarna Garden
Headbolt tension
Hi Belinda, I am not sure what you are asking for when you say headbolt. If you mean cylinder bolt, jug bolt or head bolt then
approximately 125 inch pounds.. not foot pounds!!!
This image I found for a Poulan chainsaw site, Poulan makes most of Craftsman saws. If you match the size you should find your torque setting.
jeromekj
Apr 20, 2014 | Craftsman sears 18" Chain Saw Chain (...
I need head bolt torque specs for a 2000 cadillac deville dts..
DeVille, Eldorado, Seville 1999-2005
Cylinder Head
Print
Removal & Installation
Left Side
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system.
  3. Properly relieve the fuel system pressure.
  4. Remove or disconnect the following:
    Negative battery cable Exhaust manifold Alternator Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Power steering return hose retaining bolt from the cylinder head 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket.
  5. Clean the head mating surfaces.
To install:
Fig. Left cylinder head bolt torque sequence-4.6L engine
  1. Install the cylinder head with a new gasket. Lubricate the bolts with engine oil prior to installation.
  2. Torque the M11 bolts in sequence as follows:
    1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees
    2. Step 2: Turn an additional 60 degrees
    3. Step 3: Turn an additional 60 degrees (total 190 degrees)
  3. Torque the M6 bolts to 106 inch lbs. (12 Nm)
  4. Install or connect the following:
    Power steering return hose retaining bolt to the cylinder head and tighten to 37 ft. lbs. (50 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
  5. Change the oil and filter.
  6. Fill the cooling system.
Right Side
    Negative battery cable Exhaust manifold Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Electrical connector from the Engine Coolant Temperature (ECT) sensor Nut attaching the coil cassette ground wire to the cylinder head Bolt attaching the exhaust crossover pipe to the cylinder head Bolt attaching the right transaxle mount bracket to the cylinder head Bolt attaching the rear transaxle brace to the transaxle Nuts attaching the rear transaxle brace to the cylinder head Rear transaxle brace 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket
To install:
Fig. Right cylinder head bolt torque sequence- 4.6L engine
    1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees.
    2. Step 2: Turn an additional 60 degrees.
    3. Step 3: Turn an additional 60 degrees (total 190 degrees).
  3. Torque the M6 bolts to 106 inch lbs. (12 Nm).
    Rear transaxle brace over the studs located at the rear of the right cylinder head Nuts attaching the rear transaxle brace to the cylinder head, loosely Bolts attaching the rear transaxle braces to the transaxle and tighten to 37 ft. lbs. (50 Nm) Nuts attaching the rear transaxle brace to the cylinder head and tighten 37 ft. lbs. (50 Nm) Electrical connector to the ECT sensor Bolt attaching the exhaust crossover pipe to the cylinder head and tighten to 18 ft. lbs. (25 Nm) Nut attaching the coil cassette ground wire to the cylinder head and tighten to 13 ft. lbs. (17 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
Apr 16, 2013 | 2000 Cadillac DeVille DTS
I need the torque for all the head bolts on my 1983 datsun 280zx
Check this information for 1983 Datsun 280ZX 2.8L (click over image for zoom)...
Fig. 7: Cylinder head bolt removal sequence
Fig. 13: Head bolt torquing sequence-1970-83 models
After repair job, temporarily install and tighten the two center (right and left) cylinder head bolts to 14 ft. lbs. (18 Nm).
Install the camshaft sprocket together with the timing chain onto the camshaft. Make sure that the marks made earlier, line up. If the chain will not stretch over the sprocket, the problem lies in the tensioner. Refer to the Timing Chain removal and installation procedure for the timing procedure, if necessary.
Install the cylinder head bolts. Note that two lengths are used. Tighten the bolts in sequence.
1970-71 models:
Tighten the bolts to 33 ft. lbs. (43 Nm)
Tighten the bolts to 47 ft. lbs. (61 Nm)
1972 models:
Tighten the bolts to 55 ft. lbs. (71 Nm)
1973-83 models:
Tighten the bolts to 30 ft. lbs. (39 Nm)
Tighten the bolts to 44 ft. lbs. (57 Nm)
Tighten the bolts to 54-61 ft. lbs. (70-79 Nm)
To complete the installation, reverse the removal procedures. Adjust the valves to a preliminary COLD clearance of 0.2mm for the intake and 0.25mm for the exhaust. Operate the engine until it is at normal operating temperature, retighten the head bolts (loosen them slightly and retighten to the final torque figure) and adjust the valves to the HOT clearance specifications.
Hope this helps; remember to rating this answer and leave some testimonial comment about this.
Oct 13, 2011 | 1983 Nissan 280ZX
What is the torque number sequence for a 2001 oldsmobile aurora 3.5 v6
Assuming about cylinder head...
Fig. Front cylinder head bolt torque sequence - 3.5L (VIN H) engine
  2. Install new M11 bolts and M6 bolts.
  3. Torque the M11 bolts in sequence to:
    1. Step 1: 30 ft. lbs. (40 Nm).
    2. Step 2: 100 degree turn.
    3. Step 3: 100 degree turn.
  4. Torque the long M6 bolt to 22 ft. lbs. (30 Nm).
  5. Torque both shorter M6 bolts to 106 inch lbs. (12 Nm).
  6. Install or connect the following:
    Lifters Rocker arms Camshafts Primary chain
  7. Remove the timing chain holding tool.
  8. Install or connect the following:
    Camshaft covers. Torque the bolts to 80 inch lbs. (9 Nm). Exhaust manifold. Torque the bolts to 22 ft. lbs. (30 Nm). Coolant crossover pipe. Torque the bolts to 18 ft. lbs. (25 Nm). Intake manifold. Torque the bolts to 62 inch lbs. (7 Nm). New oil filter Negative battery cable
Hope helps.
Mar 29, 2011 | 2001 Oldsmobile Aurora
Whats the proper order and torque specs for a 99 32v northstar head?
REMOVAL & INSTALLATION NOTE: The manufacturer recommends that the entire powertrain be removed from the vehicle before removing the cylinder heads.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    • Negative battery cable
    • Powertrain assembly
    • Intake manifold
    • Cam covers
    • Harmonic balancer
    • Timing chain front cover
    • Oil pump
    WARNING
    Align all timing marks before performing the next step.
    • Chain tensioner from the timing chain
    • Cam sprockets
    NOTE: The timing chain remains in the chain case.
    • Timing chain guides, access for the retaining screws is through the plugs at the front of the cylinder head
    • Water crossover
    • Exhaust manifold
    • Cylinder head bolts by reversing the torque sequence
    • Cylinder head and discard the gasket
    WARNING
    With the camshafts remaining in the cylinder head some valves will be open at all times. Do not rest the cylinder head on a flat service with the cylinder face down, or valve damage will result. NOTE: Clean all gasket mating surfaces. Clean the head bolt holes in the crankcase. WARNING
    Be careful when cleaning aluminum gasket surfaces to prevent damage to the sealing surfaces.
  5. Check the cylinder head for warpage; it must be less than 0.002 in. (0.05mm). If the cylinder head was resurfaced, the dimension between the combustion chamber gauge pad and the deck surface must be at least 10.5mm. To install: NOTE: Refer to Section 1 of this manual for the cylinder head torque sequence illustration. The illustration is located after the Torque Specification Chart.
    • New cylinder head gasket
    • Cylinder head, lubricate the bolts with engine oil
  7. Torque the M11 bolts, in sequence, as follows:
    1. Step 1: 22 ft. lbs. (30 Nm).
    3. Step 3: Turn an additional 60 degrees (total 180 degrees).
  8. Torque the M6 bolts to 106 inch lbs. (12 Nm).
  9. Set the camshaft timing
  10. Camshaft guide bolt access hole plugs in the cylinder heads. The plugs should be seated and snug
  11. Install or connect the following:
    • Intake cam covers
    • Oil pump
    • Harmonic balancer
    • Cam sprockets
    • Chain tensioner to the timing chain
    • Intake manifold
    • Water crossover
    • Exhaust manifold. Torque the nuts to 22 ft. lbs. (30 Nm) or the bolts to 18 ft. lbs. (25 Nm).
    • Negative battery cable Fig. 1: Minimum head resurface dimension 7922vg04.gif
  12. Fill the cooling system.
  13. Evacuate and charge the air conditioning system.
  14. Run the engine and check for leaks.
Aug 19, 2010 | 1999 Cadillac DeVille
Torque setting cylinder head bolt 4 cylinder KIA sportage
I need the torque settings and pattern for a Kia Sportage 2.2
Nov 24, 2009 | 2001 Kia Sportage
Replacing cylinder head on 1986 montero with 2.6 timing chain. just need timing marks and head torque specs.
ok
42011354
  1. Torque all bolts except No. 11 to 69 ft. lbs. on a cold engine or 75 ft. lbs. on a hot engine.
  2. Torque cylinder head to chain case cover bolts (No. 11) to 156 inch lbs.
  3. 42011356
Sep 17, 2009 | 1986 Mitsubishi Montero
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Garden Logo
393 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
