Question about Mtd 22" Yard Machine Push Mower
My snowblower runs for about 5 min then wants to die. If I play with the chock it will run a bit then try and die. Then it mite rev up & down ?
  • 1 more comment
  • Theron Ladinsky Feb 18, 2012
    Yes this did the trick. I loosen the gas cap and let it run for about 20 min It run fine. Thanks !
  • eastnorthsho Feb 18, 2012
    It's your call now whether to keep the Cap slightly loose, buy a replacement cap or figure out how that cap vents and clear the vent.
    Glad that got you running again
  • wadingriver
    wadingriver Feb 18, 2012
    There you go.
    Glad you semi solved the problem. Now you just have to find out why teh Cap isn't venting
Briggs & Stratton 11 horse snowblower engine pulsating
this i what my pressure washer does... I would say its just getting aged and you shouldnt have to worry about it, but if you want to try to get it to stop then give it a good tune up. spark plug air filter and clean the carb out with a small wire or tourch tip cleaner to make sure all the passages are clean and clear... or just let it keep doing it like I do.
Feb 10, 2013 | Garden
Stalls when chock is in run position
hello ,your engine is a tecumseh HMSK90-156525D, Sounds like carb. may need adjusting. Take the heat box off to expose carb. the heat box is the metal box surrounding the caeb., there should be 2 adjustment screws- 1 on the bottom of the bowl and 1 on the side of the carb just above the edge of the bowl ( depending how the carb sets off the engine - if the carb comes straight out it will be on the side facing towards the front of the snow blower or if it goes towards the handles then standing other side of the snow blower the screw will be facing you), turn both screws in til they just bottom out the turn them out 1 1/4 turns out then start the machine. While the machine is running at low idle turn the screw on the side of the carb. in (clockwise) a little at a time listening for the engine to start to rev up and then start to rev down, bog or studder then turn back slightly to bring idle back up. Once the idle is up then the screw on the very top of the carb. turn that out to lower idle to a normal idle. Repeat those adjustments till you cant get the idle to go up anymore. Now for the screw on the bottom of the bowl- move the throttle up to max and turn the screw in till you hear it rev up higher and starts to bog or sputter then turn it back slightly to bring the high rev to a smooth rev. That should take care of it. If it does not solve it then the carb may need cleaning then the adjustments done again. If you need more help on this please feel free to ask. Sometimes you have to do process of elimination and you start with the easiest first. Also the adjustments should help with the carbon build up on the plug.692509.pdf (application/pdf Object)
i have included the manual to give you a good understanding of the carb, page 7 to 25, hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you.00
Feb 23, 2012 | Tecumseh Snowblower Snow Blower Starter...
Cleaned everthing top to bottom ,bike sat for a while gas was bad,it idels fine,but now when i give it gas it dies,i think its the auto choke?it puffs black smoke when it dies,can u dissconect chocke?
try replaceing the slow jet inside the carb its 3.95 part little brass screw inside card tech at harley said if that jets plugd bike wont hold a idle it mite start but no idle i replaced mine and bike runs fine i had the same problem trust me that little screw will be the difference in running and not running it has tiny pin holes that will never be cleand out good enough spend the 4 bucks its worth it easy fix take carb off remove the bottem of carb off ull see the jets the slow jet is the 1 that is deep down the hole its a little brass screw with pin holes in it
Jul 10, 2011 | 2001 Buell Blast
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Briggs and Stratton dies after 15 mins
sounds like the head bolts maybe lose just check that first
Dec 26, 2008 | Garden
Mtd 22" Yard Machine Push Mower Logo
79 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
