Question about Logitech Z623
Plugged in heard a pop noise now no power
Had my Logitech system shipped from the U.S. to France with all my other gear. Plugged in my speaker system, pushed the power button and then nothing. I think it had a power surge because of the different voltage here but since it's PC gear shouldn't it work everywhere? Now no signs of life are in these speakers at all. Is their a fuse? I am guessing no because it is all hard wired. Any suggestions on repair if possible. Thank you.
    Top Expert:
  • Logitech Master
  • 48,382 Answers
Power voltage differences cause burn outs in power supplies
if it is a 120 volt supply unit and you plugged it into 240 volt supply then to bad so sad --junk it
Posted on Jun 23, 2017
SOURCE: Logitech x 230 speakers "dead"
try checking to see if the mute button is on.
Posted on Nov 25, 2007
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
  • 108 Answers
SOURCE: Logitech x530 hissing noise
Yes, it is definitely the speakers themselves. Is it an extremely loud hissing noise, or soft and just annoying? most speakers tend to give off a small amount of noise when put on loud volumes. This is especially true of Logitech, because while they are a great company (I personally have their G15 keyboard, MX revolution mouse, and both the Z-680 and Z-5500 speaker models, and love them), they tend to use cheap parts to cut costs. If what you are experiencing is pretty loud, however, you may want to call them up again.
It is most likely either the amplifier itself, or one of the speakers. listen to each speaker independantly- do you hear one in specific making the hissing sound? if so, you found your culprit, and you can call logitech again to fix that problem, telling them which speaker it is. if the sound is being distributed equally, among all 5, then the amplifier is the culprit.
hope this helps.
Posted on May 27, 2008
SOURCE: speakers won't turn on
Have you checked the fuse in your plug. If the fuse has blown it won't work in any wall socket. Change the fuse for a new one anyway, then try again.
Posted on Sep 30, 2008
SOURCE: I need a replacement for my logitech z-2300 speaker wired remote control. How and where can I get one?
As strange as it sounds, I am also looking to purchase a broken remote for the z-2300. Please email if you have one,, thank you!!
Posted on Jun 05, 2010
I plugged my Logitech Z623 (110V) into a 220V output. Made a 'pop' noise and now it doesn't work. What parts need replacing and how would I do this?
Take unit apart an look at power supply. It could be just the solid state fuse popped. Power supplys are not hared to repair, the diodes are about .50 a piece, the caps about $1 a piece or so. Hopefully ot did not reach the speaker, an i doubt it did.
Oct 12, 2014 | Logitech Z623
Hello, I own logitech speakers x-530 composed all Gerawe and it looks good only in that they do not make no noise please help me ...
I assume that you are trying to run them from a pc, try plugging them into another sound source like tv headphone socket or a media player to see if any sound is emitted from these, if sound is heard then its to do with your computer. Check your sound output settings to make sure the pc isn't muted or turned down and ensure that you are plugged into the green socket on the back of the pc.
May 06, 2011 | Logitech X-530 Computer Speakers
My logitech x-210 speakers make a buzzing sound
Sounds like the speakers are not plugged in to the computer, or are plugged in to the wrong socket.
The speaker socket on a PC is usually green, a 3.5mm stereo socket.
Apr 23, 2010 | Logitech X-540 Computer Speakers
Getiing static noise through my logitech speakers when power on and volumn turned off,they sound perfect when using but to get rid of the noise i have to turn off
Hi , just make double sure all the plugs from the Speakers are plugged in correctly , and none of them are touching your Case , as that does cause that noise aswell.
Dec 29, 2009 | Audio Players & Recorders
I plugged the speakers in but it keeps making noises
Just remove the speaker pin that you inserted in pc and plug in again.
Aug 31, 2009 | Logitech R-10 Computer Speakers
Plugged my computer into a 220 outlet!
You burned the Power supply you don't need to switch motherboard out just knew power supply. And in the future there is a switch located on the back of them that will make them a 220v powersupply. But usually only a high end PC for gamers will need that so just put in a new powersupply and you should be good
May 03, 2009 | Logitech R-20 Computer Speakers
It is possible that either the speakers or the sound card have an internal fault. The best way to isolate this type of problem is to use a different audio source than your sound card uses in order to test the speakers. You can use a portable CD player, the headphone jack on your CD or DVD drive, or the headphone jack on your VCR, for example. In some instances, the speakers have been known to pick up noise from an external source. This is difficult to isolate as just about every electrical device in your house/office gives off some amount of radio frequency (RF) or electromagnetic interference (EMI) signals. Some of the more common items that can cause noise are: Your monitor Fluorescent lights An uninterruptable power supply (UPS) The computer itself Fans Turn off as many of these devices as possible before you test your speakers. Also, if your speakers are plugged into a power strip or UPS, try plugging them directly into the wall outlet instead. Good luck
Jan 03, 2006 | Gateway GMAX 2100 Computer Speakers
Logitech Z623 Logo
285 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
