Question about Food Mixers
How do you test a 1kvolt ceramic capacitor? - Food Mixers
Hi Mixers,
You can test a 1kvolt ceramic capacitor;
a) using a capacimetre; replacing with other one of the same type; connecting it in a 12V oscillator circuit with a LED as output wich shall blink in a frequency determined by the capacitance, says, fast with low capacitance and slow with high capacitance. Normally ceramic HV capacitors are of small capacitance for use in high switching circuits or as a protection of a power switching transistors in modern power supplies
Posted on Feb 13, 2012
What model kitchenaid was made in december of 1973?
Is the brushed band around the head missing or worn off? The model is on that band. If it worn or missing in order to correctly answer your question I need more information. Is your mixer a tilt head or a bowl lift variety? Did you look on the bottom of the base for a serial number? Some models had them there. Can you describe the ceramic piece a little better? Many models shard the same internal parts and it might not be too difficult to locate that part.
Aug 03, 2014 | KitchenAid K45SS Classic Stand Mixer
Hobart A200 won't start
If the gearing is all free to move and you replaced the motor capacitor that only leaves the motor. If you can remove the motor and test it "out of the gearing" that would confirm it. You have wired the capacitor correctly and used the correct one? Just asking! Are you sure the gearing isn't jammed up?
May 13, 2014 | Hobart A200 Stand Mixer
Replacement 7qt ceramic insert for slowcooker
You can a new one for what stoneware cost.
Dec 06, 2012 | Wolfgang Puck Food Mixers
Motor not spinning in hobart 60 qt mixer
Check manually after disconnecting the motor if this is jammed. If so the motor must be reset as the bearings are faulty and so the rotor seems to get stuck with the coil core.
Also if there is high drain with heat it is possible that the coils are faulty and might need an insulation failure test.
Nov 22, 2011 | Hobart H600 Stand Mixer
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Have a A200 Mixer, when turned on, you have to spin it by hand then it runs fine. Whats wrong
The answer is clearly in the starting circuit which doesn't have too many parts, but depends on the type of starting circuit your mixer uses (electronic or mechanical start switch). I'm assuming your mixer isn't very old, as the old units used brushed motors which did not have starting circuits.
The parts of the starting circuit are the motor start winding, the start capacitor and the start switch (probably electronic in your case which is a small silver box with four wire terminals on it). The capacitor should be tested with a multimeter after verifying it's not holding a charge (check with multimeter set to DC Volts, mixer unplugged, should read zero volts).
Start winding should be tested with the meter to measure ohms. Locate the wires leading to the motor (hopefully only three wires) and you should get a reading for all three combinations of measurements (wire 1-to-wire 2, 2-to-3, 1-to-3) if meter indicates open on any of these, motor stator is bad(this is pretty rare and quite expensive).
Electronic start switches are not very simple to test, but if the capacitor and motor test out OK with the meter, and all the wiring is intact (look closely for loose wires, burned wires, poorly crimped terminals, etc.) then it must be the start switch.
May 19, 2010 | Hobart A200 Stand Mixer
Kenwood chef A701A capacitor and other components.? I thought it would be a good idea to replace the capacitor on my Kenwood Chef A701A because of its age and before it blows!! Can you tell me if the...
The 0.1 microfarad can be safely replaced with a 275 VAC 0.1mF mains capacitor. You can remove the clip that held the old electrolytic capacitor by sliding the old capacitor out and squeeezing the metal clip so that it disengages with the plastic base. The load resistor is 450 Ohm 15W or 20W wirewound. There is a 56 ohm resistor in series with the capacitor which helps smooth the speed change and reduces wear on the contacts. A 2W wirewound resistor works best. (It is worth removing the contacts and removing any pitting or carbon build up with fime emery paper). I have repaired about 20 speed controls sucessfully with these components.
Sep 10, 2008 | Kenwood KM800 Major Classic Stand Mixer
Smoking Kenwood Chef A901
I have just had the exact sme problem.
It is caused by a 1 watt resistor on the board.
You will also find that very possibly the large capacitor, a 0.1uF, has aso burnt out. This capacitor would have cracked open down the side and that is where the smoke came from.
parts can be replaced by a repair man and possibly a better solution is to have the board replaced, They are availiable still.
Apr 02, 2008 | Kenwood KM800 Major Classic Stand Mixer
Capacitor value needed for KitchenAid stand mixer 3-C
hey had the same problem with a k5a they have them at radio shack part 272-1053 hope this works on yours
Dec 27, 2007 | KitchenAid Food Mixers
Food Mixers Logo
53 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
