Destop PC sudenly the screen became black
Dark screen, HD LED does not light but motherboard LED is always on. LCD monitor is good. I swapped memory mudules, unpluged HD, installed other graghic card and nothing worked. Please help!
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin IDE it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Posted on Feb 14, 2012
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
Screen is too dark and unreadable fix it
The screen on what make and model device?
Jul 10, 2013 | Computers & Internet
Laptop screen went black
When I opened my laptop this morning my computer won't come on. The screen is totally black. I took out the battery and put it back in ---- still nothing. I plugged it in with the power cord --- nothing! What is wrong with my HP Compaq Presario CQ60?
Jan 04, 2010 | Compaq Presario CQ60-220US PC Laptop
Ma acer aspire 5738z does not start at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Oct 16, 2009 | Acer Aspire 5735 Notebook
Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Sep 28, 2009 | Acer Aspire AM1640-U1401A Desktop PC
Sudenly the screen went black but in first sight the screen became with stripes/colors liners
The most likely culprit is your inverter. Most black or dark screens are caused by a faulty inverter. In rare cases (about 10%) the screen or backlight needs to be replaced.
Jul 30, 2009 | Computers & Internet
The monitor screen goes dark about 10 minutes
Please verify the power option setting present in 'control pannel' option once. If you have selected to turn off the power supply after 10mins, (once the system is in idle state) then the SMPS will stop supplying power.
thanks.
Jul 20, 2009 | BenQ FP71G 17" LCD Monitor
T60 screen stays black and won't come on
any activity on the hard drive LED? If there is, hook up an external monitor and see if you can get a picture that way.
If you don't have any activity from the hard drive light LED and the screen stays dark then try unseating and reseating the memory one stick at a time in each slot one at a time and turn on the laptop after each stick reinsertion.
If after that you stilll don't have video the motherboard is bad. Also you may want to try a good known stick of memory in each of the slots to make sure your existing memory sticks are good.
Jun 29, 2009 | IBM Computers & Internet
IX PACIUP4240 15'' LCD, No POST or boot
The error message "CABLE NO INSERT" refers to the lack of video signal to the LCD. To fix it you have to use a short VGA cable that connects VGA output of motherboard to VGA input of LCD. Only then you are going to see video output on LCD screen. Your other option is to connect external monitor to VGA output on motherboard. Either way you are going to see motherboard's video.
Oct 16, 2007 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
Computers & Internet Logo
David Payne
David Payne
