Question about Bosch TASSIMO Coffee Makers & Espresso Machines
Tassimo TAS 20
I have de-scaled this unit, but still am getting little water through system, to brw each cup of coffee. I have cleaned unit, but still nothing. This didn't start to happen until after I had started brewing Peppermint Mochca T-cups. Any ideas what I can do to fix the problem?
SOURCE: Braun Tassimo Coffee
It's most probably from the overflow which is situated behind the splashback. When the machine leaks from there it generally means that it needs to be descaled. You can use a general descaling agent powder. dissolve it into the water container filled to max, with the cleaning disc run a few cycles with 15 minute gaps between each cycle. after it should be fine.
Posted on Nov 29, 2007
SOURCE: Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
Posted on May 19, 2009
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Posted on Sep 30, 2009
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
Red steam light won't go off
probably needs to be cleaned - use the cleaner disk and run the cleaner solution through it
Sep 16, 2014 | Bosch Tassimo TAS 4012 Coffee Maker
Tip
De-Scale Keurig coffee units
<br /><br />The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.<br /><br />Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.<br />Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.<br />If you taste vinegar..use more clean water, until the taste is ok.<br /><br /><br />
on Dec 22, 2010 | Coffee Makers & Espresso Machines
Bosch Tassimo TAS4513UC 1-Cup Coffee Maker manual
I looked up your problem and found the same one was answered previously on fixya. I have copied and pasted the previous answer here for you. Good luck and I hope you have a great day!
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Mar 25, 2014 | Bosch Tassimo TAS4513UC 1-Cup Coffee Maker
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
When my coffee starts to brew, the coffee (water) does not come down in a nice single stream. It is all spread out (kind of like water rolling off an umbrella) and some of it misses the cup. Also, alot of...
Sorry to read about your issue.
in addition to below take a pin and clean the little tube
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Keurig B60 Coffee Maker
When k cup is placed in machine no coffee comes out, with out k cup water comes out
sfd
also clean the holes at the bottom of the k cup holder
Dec 24, 2010 | Keurig Platinum B70 Coffee Maker
I haven't had my keurig for a year. This morning I brewed 2 cups with no issue. I went to make my third and the lights flashed momentarily and then the screen went blank. Now I can't get it to even come...
Sorry to read about you issue.
try and unplug the unit and try again..if the unit starts again i suggest you follow the procedure below. if not the unit is defective....
Dec 21, 2010 | Keurig B60 Coffee Maker
After brewing, unit occasionally fails to refill tank and shuts self off. Usually if unit is turned back on, it will refill.
Dec 19, 2010 | Keurig B70 Coffee Maker
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
171 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
