Question about Maytag Centennial MTW5800TW Top Load Washer
How to replace the water inlet valve on a Maytag Centennial
aborcass
  • 2651 Answers
SOURCE: water leak
you would acess ut from under the main top. alittle involved but acessable,.. you need to remvoe teh four phillipsscres from with in the soap dispensor area. then remove the front door as well as th e2 screws oppisite t eh door hinge, then pop off the front cover. from there youll find 2 more 5/16 screws holding the top to the frame assy. then the main top can be flipped backward allowing you acess to the valve
Posted on Nov 03, 2008
  • 130 Answers
SOURCE: My Neptune washer is leaking water from underneath.
Yes they are the same.
Posted on Jan 26, 2009
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
sclarke7
  • 222 Answers
SOURCE: maytag mah6700 will not stop filling with water
your drain hose is too far down the drain pipe in the wall it should only go down approx 6 or eight inches, after putting the drain hose in the correct position secure the drain hose to the water lines with a zip tie or tape so that it will not move
Posted on Aug 27, 2009
SOURCE: Overfilling maytag centennial - brand new?
My Maytag has a load size sensor that automatically fills the tub with the appropriate amount of water. This sensor gets over-ridden if the lid is opened while filling. In other words, don't open the lid during the cycle. If you do, the machine will fill to the top as if there is a huge load in the tub.
Posted on Jun 21, 2010
Why won't my maytag Centennial mvwc400xw4 fill with water?
either the inlet valve needs replaced or the control board
Jun 30, 2017 | Maytag Washing Machines
I have a 2010 Maytag Centennial (MVWC300VW1) washer. In the fill mode using hot or warm water setting, it stops filling after 20 seconds. I have replaced the water inlet valve how ever the problem is still...
Hi Daniel.
I've heard of this problem before. In that case it was because the water pressure was too low and the inlet is set for higher pressure.
If you have a low pressure (gravity) delivery you may want to check if there is an inlet specifically designed for LOW water pressure.
Good luck
Nomess
Dec 29, 2014 | Maytag Washing Machines
Push button , locks machine but no water fills
check your cold inlet water solenoid valve , remove blue hose and check you have water to machine if ok check you have power to valve if you have power and water and still no water going into machine then its your valve that needs changing ,
Jul 09, 2014 | Maytag Centennial Top Load Washer
The hot water will not fill
Please check the INLET to the hot water line. It could be clogged.
of so remove and flush or replace valve, if there is no supply to the valve it can be related to the control panel.
Feb 12, 2013 | Maytag Centennial MTW5800TW Top Load...
My Maytag Centennial Washer is a top loader. It washes fine, but will not spin out after the rinse cycle.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jan 21, 2013 | Maytag Washing Machines
How do i clean the water hose filter
On the back of the Washer, you have your hot and cold water hoses that hook up to the Washer Water Inlet Control Valves. Shut the water off at the Main water valves in the wall. Disconnect the hoses from the Washer and check the filters inside the Water Inlet Control Valves.
Mar 14, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water not coming into washer
water will not enter the tub. Replaced water inlet valve. Checked inlet voltage 120v. No outlet voltage at water inlet valve.
Jan 07, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial MTW5800TW Top Load Washer Logo
331 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
