Question about Acer X193W LCD Monitor
I have a Acer x193w+ and the screen suddenly went white.
I dual screen montiors and it was the secondary. It turns on and get's power. My computer recognizes it's there and active. I can see windows and programs go to it, but it only displays a white screen.
  • Thomas Ladwig Feb 13, 2012
    I dual screen montiors and it was the secondary. It turns on and get's power. My computer recognizes it's there and active. I can see windows and programs go to it, but it only displays a white screen. I've tried connecting it to another computer and changing the cable but to no effect. And to top it all off the warranty is out.
Benimur
  • 6966 Answers
SOURCE: Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
SOURCE: Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Posted on Dec 30, 2008
  • 408 Answers
SOURCE: why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Posted on Mar 06, 2009
  • 105 Answers
SOURCE: Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Posted on Oct 19, 2009
  • 109 Answers
SOURCE: AC713 (White) (Black, Ivory) 17" CRT Monitor: acer x193w lcd monitor , its on & immediatly o...
problem with ccfl lamps or inverter, you need to have it service,,
Posted on May 09, 2010
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
What will show on the screen if you connect lcd acer x193w only electricity? (Without the PC you plug inserted in lcd acer x193w.) I show my "Acer" and turns off, then starts again and goes off...
Normally when you don't plug a monitor into your computer but just into the wall socket then you should get a No Signal message displayed. If the monitor is behaving erratically then it's not a good sign. Try plugging the monitor into your PC as well and see if it still keeps switching on and off.
Apr 17, 2011 | Acer X193W LCD Monitor
Oct 19, 2009 | Acer X193W LCD Monitor
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Why do I get a "No Signal" on my Acer x193w monitor?
Feb 24, 2009 | Acer X193W LCD Monitor
Shadows
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Feb 07, 2009 | Acer X193W LCD Monitor
Nov 08, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
