Question about Brother Office Equipment & Supplies
Dcp 540 cn error 51
Unable to clean error 51
3 Suggested Answers
jay767
  • 386 Answers
SOURCE: Brothjer DCP-540 CN - unable
Try to reset DCP printers without numeric keypad.
Follow this:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Don't forget to vote Thanks!!!
Posted on Jan 05, 2011
Samyfam
  • 379 Answers
SOURCE: error 50 afte paper jam
The following is an extract from the Brother Service Manual that covers your machine:
"Error Code 50 & 51: The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses."
The manual lists seven different causes, best case being the need to clean part of the mechanism, the worst case being replace the whole main electronics board !
Unless you have very good skills for dismantling such a complicated machine*, your choices are take it to a Brother Service agent who will probably charge you more than a new machine, or bin it - sorry !
* If you want to have a go at dismantling it, the service manual can be bought on eBay for about £5. If you don't want to spend that much, I can supply you a .PDF file copy for £1 - just post back here and I'll sort it out.
Posted on Jul 07, 2010
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
MY BROTHER PRINTER DCP-395 CN ERROR IN UNABLE TO INTI 4F PLEASE SOLUTION
This error is associated with the self test the printer does on the print head during power-up of the printer.
Sadly, it is indicative of either a faulty print head or a faulty main control board, neither of which are easy or inexpensive to replace.
Unless you can get hold of another machine with a different fault and swap over the print head and/or board (you'll need very good skills and tools to do this) then I'm afraid the machine is beyond economic repair*.
* Brother will repair your machine but the cost will likley be more than a new one.
Jul 09, 2014 | Brother DCP-330C All-In-One InkJet Printer
'unable to clean 35' error on mfp brother dcp-j125 printer
Feb 15, 2012 | Office Equipment & Supplies
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Brothjer DCP-540 CN - unable to clean 46 what do I do?
Follow this:
Jan 05, 2011 | Brother MFC 420CN All-In-One InkJet...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Error 50 afte paper jam
Feb 20, 2010 | Brother DCP 115C All-In-One InkJet Printer
Model DCP 120C-UNABLE TO CLEAN-
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and your printer need service.If error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then'menu' one by one...
2. Press the arrow up or down to go to'maintenance 80'.
3. Press 'mono start' several times to go to'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered thiscombination, the purge numeric value will be reseted to 00000.
Oct 22, 2009 | Brother DCP-120C All-In-One InkJet Printer
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Error message on MFC 440-CN
error 51: problem with purge station or travel path way of printhead. You cant fix it by yourself.
If it is still in guarantee give it to a service dealer after calling brother hotline.
Nov 27, 2007 | Brother MultiFunction Center MFC-440CN...
855 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
