Question about Juster 3D-102 Computer Speakers
The subwoofer on light does not come on and the sound has stopped working after working for a few years. What could be the problem
It was playing ok. Then I tried switching it on the next day but nothing worked.
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow question / exclamation ? ! mark or a red X right click to update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Posted on Feb 14, 2012
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
Synergy 10 sub light is on, but no sound
Pop the speaker out and make sure the spade terminals are still hooked up.
Mar 18, 2013 | Klipsch Audio Players & Recorders
Unit was working for a couple of months. Then I noticed some cracking sound coming from it then the sound stopped coming through. It came back for a few minutes then it has not worked since. This is all on...
sorry, but from your description i dont think there is much help for your sub. unless its new and under warranty. that sounds very typical of a dead sub. i have had a bad run in with sony products just quiting only after a few years. i try to stay away from anything with the word sony on it. a short list of the sony products that i can rememdying only after a year or so cd boom box (3 of the same one) sony 19" tv, sony handi cam (video camera two weeks after warranty peroid), component cd player, alarm clock radio.... the list is longer but i will stop. sorry for your trouble.
Dec 24, 2010 | Sony SA-WD200 Subwoofer
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
Subs cutting out
Agree with Kev. Even if the woven lead wire looks ok, it can still be bad. I unsoldered it, clipped a lil from both ends, and re-soldered it. Works great now.
Sep 11, 2008 | Infinity Reference 1230W Car Subwoofer
Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Feb 11, 2008 | Velodyne CT-80 Subwoofer
Red light when power is "ON"
no not at all you enjoy sound ok...
Nov 20, 2007 | Altec Lansing VS4121 Speaker
Smoke coming out of subs
If smoke has come out of the subwoofer, the speaker itself, that means the voice coils have been heated excessively and they are damaged or in this case, I'd say completely blown. Voice coils blow because they've been driven too hard, too much power, too much distortion for too long.
If you can get access to the front of the subwoofer speakers, gently put even pressure with your fingers near the middle of the cone, just around the edge of the centre dust cap and push gently and slightly inwards. If you hear or feel a "scratchy" type sound or feel, or if they dont move in freely, they are blown. And if that's the case, your amp could be damaged as well.
Most modern car amps have circuit protection and will shut down when they detect a load greater than they are used to so the amp MAY be ok. One way to test the amp is to hook another speaker to it, any speaker as a test is ok, and see if sound comes out. Make sure all power is off when connecting and disconnecting speakers!
Oct 17, 2007 | Jensen JX1200 Car Subwoofer
Juster 3D-102 Computer Speakers Logo
Top Juster Audio Players & Recorders Experts
Martin Murray
Victorman
Victorman
Vladimir Frolov
Are you a Juster Audio Player and Recorder Expert? Answer questions, earn points and help others
