Question about Nilfisk Vacuums
Nilfisk 125.3 losing pressure
Bought a nilfisk C 125.3 today, & followed instructions & watched youtube vids to see how to operate, tries it, but the pressure keeps dropping. The motor cuts out after about 1 minute and I get about 3 seconds of pressure before it drops to a dribble. what might I be I doing wrong? Do I need to 'prime' it somehow? Hope someone can advise. Robin
3 Suggested Answers
SOURCE: Bissel Little Green Spray Motor
Motor was seized. Probably from lack of use combined with the moisture involved with such a device. I loosened the motor with a pliers, gave it a small shot of wd-40, and off we go. Works fine.
Posted on Mar 10, 2008
ercupa190
  • 12223 Answers
SOURCE: Fault Nilfisk Alto pressure washer
see the diagram and repair swtich:
Posted on May 14, 2012
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
Need to replace cartridge. The cap at the end is supposed to come off by turning clockwise. Don't want to force. The faucet is not stainless. It is impact plastic for lack of better description.
NOT my vid but See if this helps...
watch the video. If it matches your faucet , proceed to disassembly.
Once removed follow the following:
Be sure to do a quick debris flush of the faucet (not shown in video) by opening the stops a bit. prepare for the squirt before doing so. once clean, I recommend silicon grease on all seals screws. You can acquire a small amount from an auto parts store. A small ketchup squeeze package type for auto ignition wires is usually available. Do not over apply. A very thin coat is all that is needed. It will protect and lubricate. Vaseline can be used also but with less effectiveness.
Follow re-assembly instructions.
https://www.youtube.com/watch?v=yuMqVFD5Akw
Hansgrohe How to Change an M2 M3 Cartridge
Sep 15, 2015 | Grohe LadyLux One Handle Kitchen Faucet...
Nilfisk BR1100S
http://webparts.nilfisk-advance.com/pdf/OM56041978-US,TR.pdf
This is the manual, if it ain't there, good luck. (Check A-4 and A-5):
BR1100S, BR1300S
INSTRUCTIONS FOR USE
May 07, 2014 | Vacuums
I need instructions on how to dismantle my nilfisk multi 20
Hi There,
If you need parts diagrams for any Nilfisk machines just use the contact us form on our website and we will be happy to get one for you.
Sep 30, 2012 | Nilfisk VT60 Wet/Dry Vacuum
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Nilfisk c 100.3
It may be here, although I don't see that model number
http://consumer.nilfisk.com/User,_,Manuals.aspx?L2={4F6A35DB-42CE-458B-A705-08B694F37790}&L3=%7B540D4DC1-5544-4440-8589-13F539CF4C61%7D
Dec 05, 2011 | Vacuums
How dismount Nilfisk A100 for repair 220V cable
You need at the top the button puwer and kabel return too lose, yoy can do this to put something at the site from the button. You will see 6 screws.
lose it losre also the screw at de coverd panel and this one at the backsite.
Your problem will mybe at theconnection from the power button, is burned out.
Dec 20, 2010 | Nilfisk Vacuums
Need directions on how to remove old cotton filter and install new one and same for HEPA filter on Nilfisk GM/GS 80.
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=Nilfisk+GM%2FGS+80+instruction+manual
Jim
Dec 03, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
I am looking for a nilfisk c120.2 pressure hose replacement i seem to have looked everywhere
need to be more specific,is it click an clean tube with tornado nozzel ,or 15m drain&tube cleaner.
Aug 28, 2008 | Nilfisk Vacuums
Vacuums Logo
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
