Question about Neff Microwave Ovens
Neff microwave h56420sogb. Turns itself off after 22 seconds regardless of what wattage or time is set. How do I fix this?
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave shuts off
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
Master_Tech
  • 770 Answers
SOURCE: microwave turns itself off after a couple of seconds
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Posted on Jan 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave turns off by itself after being on for 3 seconds
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Mar 06, 2009
I HAVE A SYLVANIA MIRCOWAVE THAT THE SCREEN SAYS ROAST ALL THE TIME AND I CANT SET THE CLOCK OR ANYTHING.
Posted on Jul 07, 2009
  • 228 Answers
SOURCE: Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Posted on Aug 05, 2009
Oven accidentally operated without any contents and cut out with a smell of burning. Subsequently the oven only runs for approximately 22 seconds before stopping. Any ideas?
It will require a new magnetron and possibly power supply for it. The magnetron will destroy itself if it has nowhere for the energy to go.
Feb 14, 2011 | Neff H5642 Convection / Microwave Oven
Microwave starts as normanl but cuts out after 5 seconds on all settings?
sounds as either inverter or magnetron is faulty difficult to diagnose although when mag fault usually runs for about 22 secs inverter fails sooner around 5 secs.
Apr 09, 2010 | Neff H5642 Convection / Microwave Oven
Microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Switching off after 23 seconds without heating
Hi Paul, did you get any answer for that?? My neff is giving me same problem.. if you know what is the solution can you please e-mail me to alinaseer1@hotmail.com? Regards
Oct 31, 2009 | Neff H5470 Microwave Oven
Microwave turns itself oo
it sound like the inverter unit is faulty or the magnetron is gone.the only real way to find out which is to change each one in turn,sorry i cant be any more help.if you have any more questions get back in touch,regards les
Jul 28, 2009 | Neff Microwave Ovens
Kenmore Microwave Turns itself on randomly
22 years old and you are complaining that it starts andomly, you got way more than your moneys worth for heavens sake loosen up and buy a new one. Help the economy out.
Feb 24, 2009 | Frigidaire GLMB209D Microwave Oven
Jan 05, 2008 | Neff H5470 Microwave Oven
Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Dec 11, 2006 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
170 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
