Question about Kenwood Car Audio & Video
KDC-4051UM Cannot save audio settings. Have tried holding back button.
Downloaded manual for Kenwood KDC-MP528, but instructions for setting clock time is sketchy, and can't get " clock adj." to come up, no matter in what sequence I hit instructed buttons....
Try putting the radio in standby mode and then hold the menu button in for a few seconds. Once you enter the menu, use the am or fm buttons to scroll through the menu. Then hold the seek up or seek down for a few seconds until the clock flashes, You should then be able to use the am/fm buttons and seek up and down buttons to set the hours and minutes. Once you have the time set, press the menu button again.
Aug 03, 2011 | Kenwood KDC-MP528 CD Player
Need to set clock on jensen kdc-9520
hold down clock button for about 3 seconds. then use tuning button ( bottom left ) to set hours and minutes move left for hour move righy fo minutes
Mar 28, 2011 | Jensen KDC-9520 CD / Cassette Player
KENWOOD KDC-138 SET THE CLOCK
set the unit to standby and press and hold the select button.(the up,down,left, right button on the left of the cdplayer)
Sep 08, 2009 | Kenwood KDC-138 FM / AM Receiver
SET THE CLOCK ON KDC-MP435U
Press menu button and use volume button click up or down until CLOCK ADJ comes up and Press and Hold down DISPLAY button clock should blinking use volume control button click it up or down for Hour and side to side for mins.
Aug 05, 2009 | Kenwood KDC-MP435U CD Player
Kdc mp335 aux in doesnt work
if you go to standby with your source button and then hold in your bass boost button it should bring up a menu. there should be an aux setting in there. i just did that with mine and it was there. the manual doesnt show it either.
Jun 27, 2009 | Kenwood KDC-MP335 CD Player
Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
Apr 09, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Kenwood KDC-MP442U / Perset stations
goto the stattion you want then hold down the button you wanna save it as i.e
tune into 97.50 for essex fm
then hold down button 1 for couple of seconds
Job done :)
Upfront Audio
please rate :)
Apr 03, 2009 | Kenwood KDC-MP235 CD Player
Can not set clock on Kenwood KDC228 CD Receiver
I spent the better part of an hour trying to figure out how to get the "Clk Adj" screen on the KDC-MP228. Here is the solution (dont waste your time reading the manual, it does not explain this). First, I had screwed up my settings so I did a factory reset (hold in the reset button). Then, you need to turn off Demo Mode (in standby click the Menu button and then use the control button to navigate to "Demo On". Hold the control button in to turn Demo on or off (this is different from all of the other controls in the manual). Now that Demo is off, click Menu button again and use the Control button to navigate through the options, one of which is "Clk Adj". At that point, you can follow the instructions in the manual (Hold in Control button until the clock blinks (approx 2 seconds), then use the FM/AM buttons to change the Hours and the << >> buttons to change the Minutes). Press the Control button again to save your changes. I cannot believe how difficult it was to set the clock on this device, someone should smack the developer who wrote that code.
Mar 08, 2009 | Kenwood KDC-MP228 CD Player
How to set europe freq on KENWOOD KDC-BT838U car radio
Last night i got the answer from KENWOOD Support
Press and hold in the SRC button until the unit turns off. While power is OFF,
press and hold FNC and AUTO/TI buttons, and momentarily press the SRC button to
power the unit back on. Continue to hold the other buttons until the unit comes
back on completely.
I did it and it works
Enjoy
Dec 26, 2008 | Kenwood 2005 KDC-MP5028 CD/MP3...
Setting the time on a Kenwood KDC-MP2035
Make sure the power is off before setting the clock (hold down the "FUNC" button until nothing shows but the time). Then Hold down one of the buttons on the right side for like 3 seconds until the time starts blinking. I can't remember which button it is as I don't have the unit in front of me right now. Use the track buttons to adjust the time. Hope this helps!
Dec 21, 2007 | Kenwood KDC-MP2035 CD Player
Car Audio & Video Logo
41 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
