Question about KitchenAid Refrigerators
Trash compactor makes a loud squeaking noise when compacting
When my kitchenaide kucc151gss1 is compacting it starts making a loud squeaking noise as the ram compacts. I am thinking that this has something to do with the power screw and that it just needs to be greased to solve the problem.
SOURCE: Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Posted on Jan 17, 2008
SOURCE: g.e. profile compactor gcg1540f0ss
the nut on the ram drive fell off for me and the chain fell off and then broke the grear drive. At 72$ each for the two ruined gears I don't know if I should try to repair it or get a new one.
ERRR
Posted on Apr 24, 2008
rickzilla
  • 706 Answers
SOURCE: GE Profile compactor
Here is an assembly drawing of your compactor.. Please note item # 102 ( direction switch) ..That may be affecting the perfomance of your motor or your motor may have a dead spot on the windings.. Here is a link to a website for parts that coincide with this drawing.. There isn't an awful lot to a compactor in terms of hardware so good luck.. Hope this helps..
Here's the link for parts... http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
Posted on Aug 20, 2008
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Posted on Dec 25, 2008
  • 132 Answers
SOURCE: dryer making loud squeaking noise
Replace all the drum rollers.
Posted on Mar 26, 2009
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
Whirlpool Trash Compactor, Model No. GX900QPPS2 will not compact trash. It will only make a humming noise
drive gear broke on motor shaft,drive kit #882699should fix you.appilance parts pros.com is a good place to get it.
Oct 08, 2013 | Kitchen Appliances - Others
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down...
at the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
May 24, 2011 | KitchenAid Microwave Ovens
GE profile trash compactor makes loud noise and pulsates
sounds like you have a bad ram bushing on unit... you will have to pull out and watch operation ...there is also a differential switch that tells unit when to stop that sometimes gets worn and needs replaced... it generally is at the top or on the side of bin ....most likely it is one of the two items that has failed...
Jan 05, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor will not start
key stays on but won't continue running, starts to run and then quite
Mar 13, 2009 | KitchenAid P Series Trash Compactor -...
Jenn-aire compacter can't close
Hi marigf5,
I'm Harvey the Master Plumber.
Your problem is: you cannot get your compacter to close.
First, don't force it. Chances are something has fallen behind the drawer and is in the way. Just remove the drawer and clear it. If something is broken, you still have to remove the drawer to see and repair it. If you run into trouble you might consider utilizing the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | KitchenAid P Series Trash Compactor -...
Refrigerators Logo
95 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
