Question about Sharp Office Equipment & Supplies
I want my Sharp EL-W535HT To factorise a number to a base and a power for example 256 to 2^8.I know the new Casio can do that but how do you do it on the sharp Calculator.Thanx I would really appreciate it.
  • Sharp Master
  • 7,993 Answers
I would be interested in knowing the model number of the Casio calculator that can do prime factorization. I know and own several Casios (scientific and graphing) calculators and I have not found one that does it. Some graphing calculators are able to perform the factorization with the help of an additional program.
Posted on Feb 14, 2012
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
informatica
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
ginko
  • 19396 Answers
SOURCE: Sharp EL-1801V Calculator
The manual for 1801v is not distributed from Sharp anymore.
You can download the manual for EL-1801PIII Operation Manual (240K) , It is the same model with some cosmetic difference.
Regards
Posted on Apr 02, 2008
SOURCE: need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Posted on Mar 13, 2009
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Posted on Mar 16, 2009
INTERPOLATING LINEAR REGRESSION USING sHARP CALCULATOR EL-W535HT WriteView
On your Sharp EL-W535 press MODE and choose 1 for STAT. Press 1 for line (linear regression). You should see a table with three columns (x, y and Freq). Type in all your x values (press value =), then use your arrow keys to direct the blue block / cursor back to the top of the y-column. Type in all the y-values. Once you have finished inputting your data, press CHANGE.
To find the regression equation press ALPHA open bracket and equal. This will give you the y-intercept.
Press ALPHA and the close bracket button and equals. This will give you the gradient. You can also interpolate / extrapolate. Type in your x value press 2ndF and close bracket button, this will give you the y-value at x.
You can do the same to find x but use the open bracket button instead.
Visit www.mathsatsharp.co.za for more information and a full user friendly manual :)
Aug 20, 2017 | Sharp Office Equipment & Supplies
What does the 5/4 and F mean on the display screen?
F is for floating decimal. If you do a calculation, it will present the results without rounding. For example, 1/2 would be displayed as 0.5, whereas 1/8 would be displayed as 0.125.
The 5/4 rounds the results. For example, if the number of decimals is set to 0, 1/2 is 1. Similarly, if the number of decimals is set to 2, 1/8 is 1.3.
Good luck,
Paul
http://support.casio.com/en/support/answer.php?rgn=5&cid=004001001004&qid=32&num=1
May 21, 2016 | Sharp EL-1701C Calculator
How do i enter an exponent on the
It depends on the base of the power function.
For exponential function use [SHIFT][LN] (e^x) followed by the exponent value. If exponent is negative use the change sign +/- key before exponent.
For a general power, type in the base (number), then press the [Y^x] key followed by the exponent.
For a power of 10, use the [Exp] key. Careful here. For example to enter 1.6x10^(-19), type in 1.6, press the [Exp] key, then the change sign key +/- and the exponent. Press [=]
1 . 6 [Exp] +/- 19 [=]
Sep 28, 2014 | Sharp EL-531WBBK 12-Digit 272-Functions...
How do you do hexadecimal addition on she Sharp EL-W535HT?
Press [2nd F] [x: multiply sign] to enter Hexadecimal base calculation. The digits are 0,1, ...9, A, B, C,D,E, and F.
Enter a number in Hex, press the + sign to perform and addition or - for a subtraction. Press the = sign to obtain the result.
Feb 19, 2012 | Sharp Office Equipment & Supplies
Hi I have a sharp el-W535 and want to know how to get rid of the fracton in the line editor as the answer so I can get .500 for example
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 26, 2011 | Sharp ELW535 Calculator
How do you raise to a power on a Sharp el-738 business calculato?
I don't know about this specific calculator, but there is probably a button on your calculator that has a "y" with an "x" as a superscript (exponent). Or is could be reversed. But you wanted 2^8, you would push the 2 first, then the exponent button, then the 8, and there's your answer.
Good luck.
Jul 14, 2010 | Sharp EL-738 Scientific Calculator
What calculator would you recommend for polar and rectangular formula's?
Are you serious?
No calculator purchase should be solely based on such a trivial matter.
But if you are looking for a very good scientific calculator, I would suggest the new Write View EL-W506/W516/W546 calculators by Sharp, or the FX-115ES/991ES Natural Display by Casio.
With these calculators you can see what you enter displayed as in textbooks. Naturally, they all do coordinates conversions from Polar to Rectangular and from Rectangular to Polar.
Jun 17, 2010 | Casio FX-115ES Scientific Calculator
How do i display exponents besides 2, or 3 on the sharp EL-531WH?
EL-531W SHARP:
If you want to find 5 to the power of 6 (5^6)
you hit the 5 button, then the button that says yx ( the x is in the exponent spot) then the 6 so it will looks like this 5^6 then press enter to get the answer...hope that helps!
Jul 04, 2009 | Sharp EL-531VB Calculator
334 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
