Question about Audiovox KLV3913 12 in. LCD TV/DVD Combo
My audiovox 12" kitchen under the counter tv
I can not get it to stay on i turn it on and 3 seconds later it turns off
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Audiovox FPE3000 - no pix, has sound.
Either the back light (a fluorescent) has failed or the inverter that furnishes high voltage for the tube. I'm pasting my suggested procedure below-
If it is affecting video only, the display's fluorescent back light or the power supply for it (inverter) is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a smaller separate board with some larger components on it; it will have ferrite core transformer(s) on it and some medium-size capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on either board, allow several hours to be safe since the larger capacitors in the main power supply can hold a painful voltage charge for some hours.
The section most likely to fail and cause your problem will be one that you see associated more with the display than the incoming AC line; the latter is the main power supply and its failure would result in no sound or video.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the manufacturer and install it yourself.
They are typically connected with non-interchangeable connectors.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since a failure of the fluorescent, while likely to be less common, is the second possibility.
Posted on Dec 26, 2009
Audiovox KLV3913 TV/DVD dead
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 06, 2017 | Audiovox KLV3913 12 in. LCD TV/DVD Combo
Tv wont turn on
hold the menu and input/device buttons for 5 seconds and it will blink you a 2 digit code
1-2 normal operation
2-3 i believe is short circuit protection = probably a convergence failure
here is a link to my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 20, 2010 | Mitsubishi WS-55809 55" Rear Projection...
How do you disconnect the alarm from car
you can unplug the 12 pin harness from the alarm brain under the dash or put the system in valet by turning the key on and holding the valet button til the led stays on solid as well. regards, Martin @ lessco electronics
Apr 06, 2010 | Car APS95BT3 Transmitter with 3 Button...
Need code for Audiovox LCD TV (Model LCD1900W) for COMCAST DTA
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off
Aug 28, 2009 | Televison & Video
How can I unlock it (Audiovox tv)?
you need to search your universal remote code for a audiovox code try all of the audiovox codes then once you find the right one, how you will tell is when you turn the tv off and on click menu then unlock the tv
Aug 08, 2009 | Audiovox Televison & Video
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Channel display for Sony WEGA KV32FS100 will not turn off
Most all Sony models use the same programming for the remotes. Borrow a Sony remote and push the display to turn it off.
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Turn off and on but doesn't stay on
Replace capacitors and standby pwr supply . This value ( important) 2200uf 25v, (2 suggested)1000uf 35v and 220uf 50v . Replaced and you will fixya!!. Am here for questions ok?. Thank you
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Audiovox KLV3913 12 in. LCD TV/DVD Combo Logo
66 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
