Question about Maytag Washing Machines
The lock lid button wont stop blinking so the cycle will not start
I would temporarily bypass the wiring to the lidlock with jumper wire .This will determine if the switch on the door is bad . Sometimes they will fail and cause the very same problem.
Posted on Feb 13, 2012
  • 3 Answers
SOURCE: lid locked no power
use a screwdriver in the crevice beneath the lid. Approx 4 inches from each side you will see a 1" silver piece of metal, push the tab towards the back of the machine. Once you get one side loose place something such as a screwdriver to keep it unlatched until you get the other side loose. The top should come open. And there is also a service book inside your washing machine, I fixed mine myself. Look at my other postings. Good luck!!
Posted on Nov 22, 2007
hotuna
  • 288 Answers
SOURCE: washer will not spin
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Posted on Dec 18, 2007
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
  • 1294 Answers
SOURCE: controls locked button on and other cycles light
Power shd be on. Press the "end of cycle" button on the right side for 3 seconds.
Posted on Mar 19, 2009
  • 1382 Answers
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Posted on Jul 28, 2010
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
May 30, 2012 | Maytag Washing Machines
Model wtw6500ww1, error code LD, power off power on selected cycle but wont start just blinks and locks all buttons. let it sit and then error code comes back. washer is empty but wont reset to start...
Suspect that stands for LiD. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool washing machine, M 31062, WTW4950XW0. I am attempting to use it for the first time and the Sensing Light is coming on when I press START. The Lid locks and there is a noise like the...
I have a Whirlpool model WTW4950XW0. Once i push the start button.
The lid locks, sensing lite on, machine goes through its cycle, than lid unlocks
monents later.What wrong. I was doing laundry and notice the machine making some noise on the spin cycle. I push the pause button and remove some clothes.
thats when the sensing lite keeps blinking.
thanks
Rich
Jan 01, 2011 | Whirlpool Washing Machines
Washing Machines Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
