Question about GE Profile JTP56 Electric Double Oven
My wall GE oven turns off and flashes F2
Hi my wall GE oven turns off and flashes F2 and F3 while I am cooking. Can you please tell me what it means and what can I do about it? thanks
  • bcmusiclover Jan 28, 2009
    my oven was set on 290 then the broil came on it started blinking f2 and i had to unplug it to get it to shut off it is a ge profile oven
  • Bryan Wachs Feb 26, 2009
    F2 came up on SelfClean cycle...any news?
  • 3 Answers
Check heat sensor
Posted on Nov 17, 2008
Ge Model Number JPK27WOW1WW - Flashing F3
Please confirm your model number as I only find a JKP27WW1WW.
Dec 05, 2014 | GE Ovens
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
F2 and F3 messages - shuts itself off. Any idea of what it is and how to fix it?
F2/F3 error message relates to the oven temperature sensor or thermostat faults.
The fix is normally to replace it.
This link may help if you want to do it yourself
Hope you get it fixed.
Dec 16, 2010 | GE JKP15 Electric Single Oven
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
GE ModelJTP14 oven, after 30 minutes at 350, the oven flashed a F2 code. Cooled and restarted the oven at 350, after 26 minutes it flashed F3. I have been remodeling and have taken the oven out of the...
check the codes for your particular model..they are included witht he wiring diagram that came with your oven. F2 likely means your control board (ERC) has an issue. I can't vouch for accuracy but here's another location with fault code listings Range / Stove / Oven Fault Codes
You can try turning the circuit breaker off that feeds power to your oven ( in your house electrical panel) that might work. If it does not, unfortunately it might be indicating a need to replace the control board... good luck!
Jul 13, 2009 | GE JTP15 Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
600 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
