Re: How can I remove automated date & time update?
Hi First try to Restore it by selecting Restore Only from the phone setting.After successful restore setting is done please check the time setting.Good luck
I called AT&T about this same problem..........the CLAIM they know and are working on the problem.......meantime, I cannot get CONFIRMATION with correct date of my texts, yet they go thru
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
maybe your time setting by region is not correct so go in settings and update. if you explain which is your model of motorola i could help in more details.
try going to menu, settings, date & time, and make sure the information is correct where it says "set date" and "set time." if either is wrong, enter the correct information. that should fix it. what happened is your phone thought you were sending a message earlier or later in time than you actually were, while whoever you're texting was sending messages on time. soooo all of your messages end up clustering at the top or bottom depending on if your phone's date & time is set early or late.
The Solution is that , Your Cell phone Timing is Out from World Standard Time... Or If it is correct ,reset your Mobile.... may be after that it will correct...
Please check if the date and time on your computer is correct. The Norton program can't download and install updates if they are wrong.
If the issue is not getting fixed, try re-installing the Norton program
>> download the latest version of Norton 360 Premier edition from the link www.norton.com/n360p_5 >> save the file to your desktop >> double click the downloaded icon >> it will remove the existing version and restart your computer >> after rebooting, it will install the latest version >> your product key will be automatically updated >> that's all folk, your issue will be fixed
hey welcome to fixya. I hope u 'll be fine :)) Dear first of all check your cell phone time settings, go in the settings of cell phone and then time and date, here u can change the settings, set the exact time and date and then on the auto-update of time. then restart your cell and this problem 'll be solved If u like this solution or way to solve the problem den please do rate me. THANKS
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
