Question about Symphonic WF104
Regional code for Symphonic WF104
Hi, My name is James Padley I live in Brazil. the regional code here is 4 (or 0 = all). I have a symphonic WF104, which apearently doesn´t have a hack code. I know that you can take your dvd player apart and take out a component that blocks the code but I don´t know witch component. You might say that it shouldn´t be done cause that would be nulifying the reason for the block. but I payed for a dvd I can´t use cause it is in the wrong country. I shouldn´t have to buy another dvd player - right? Do you know how to decode a dvd perminantly? or is there by any chance a code to hack a symphonic WF104? Or did they intend on only selling in the US? I apreciate any help on this matter! Yours truly, James
2 Suggested Answers
SOURCE: Symphonic DVD/CD player SD200E
works like the denon 1910 heres a link to info if you have the european version im looking for US one my self to make it region free so i can play german DVD's pal
Posted on Jun 04, 2009
  • 298 Answers
SOURCE: Symphonic WF104 Direct tv remote
Try this website
Posted on Feb 18, 2011
0 characters
1 Points
I need the universal remote code for my WF104 dvd player
It looks like there are a range of values that have been quoted online. It would appear to depend on the make of the universal remote. I have found 456 or 458 stated.
If you are using a comcast remote I have seen 0675, 10180 or 10171.
Oct 25, 2012 | Symphonic WF104
Can't find symphonic remote code for Comcast remote
10180, 10171 those are the symphonic remote codes for comcast.
Jul 18, 2009 | Symphonic WF104
Programming Remote
the codes are in the back of the remot manual or try
Jan 12, 2009 | Symphonic WF104
Jan 08, 2009 | Symphonic SD200E
Dual layer disc problem
Did you glance in the manual to see what types of DVD it would play (typ. DVD-9, DVD-4, etc.) and try it?  This site can't prevent you reading appropriate manuals, you know.
Aug 17, 2008 | Symphonic WF104
Need dvd code for symphonic WF104 I am using a scientific atlanta remote control
I'm guessing you have tried these already, but, you can try:
2017, 2213, 1029, 1134, 1150
if it is the ER1
014, 186
If that doesn't work, try a search by doing this:
Turn on the device.
2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, DVD, or
AUX) until the mode keys blink twice. For example, to search for a TV code, press
and hold SELECT and TV at the same time.
Note: If you reassigned mode keys, you may, for example, press SELECT and
VCR to search for a TV code to assign to the VCR mode key.
3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
4. Point the remote toward the device, and press PLAY . The remote automatically tests each code in its library, beginning with the most common codes. The mode key blinks once each time the remote transmits a new code. The mode key
blinks twice when it reaches the last code.
5. As soon as the device powers off, press SELECT.
6. Verify the new code is correct by pressing POWER.
7. Did the device power on again?
• If yes, press SELECT to assign the code.
• If no, complete the following steps:
a) Turn the device on.
b) Press channel up or channel down to step forward or back to the correct code.
c) When the device turns off, press SELECT to assign the code.
Apr 03, 2008 | Symphonic WF104
Symphonic WF104 Logo
82 people viewed this question
Top Symphonic DVD & Blu-Ray Players Experts
Are you a Symphonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
