Question about Motorola XTNi Two Way Radio
Need a service manual for Motorola XTNi Two Way Radio
Manual
3 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: Motorola XTNi off frequency
There are several ways:
1) Customer Programming Software (CPS)*
Allows users to perform various programming
functions. Plus, the CPS software provides access
to new features such as Radio Reporting to
manage cloning and radio profiles, Manager Lock,
Power Select, and Time-Out Timers.
* CPS is available as an optional accessory, including required USB cable.
2) Easy Cloning
Quickly copy settings from radio to radio with
either the Radio-to-Radio Cloning Cable or the
Multi-Unit Charger accessories. (Both sold
separately.)
You should be able to purchase any of this software/equipment from your retailer where you purchased the radio.
Best regards.
Posted on Dec 03, 2009
eradiostore
  • 1654 Answers
SOURCE: intermmitant transmission on a Motorola
Intermittent transmit can be caused by:
1) Bad or poorly charged battery. (try a known good battery and see if the problem clears up)
2) Poor connection to the battery. (clean all contacts with a pencil eraser)
3) Bad PTT internal button, radio would need repair.
4) Bad antenna. Check for breaks in the rubber covering.
5) Other internal problems requiring repair.
Best regards.
Posted on Mar 09, 2011
I need a manual for a Motorola TS10 radio
Bob
Contact Motorola Solutions.
Get Support
Mark
Motorola Support
Mar 22, 2014 | Motorola Radio Communications
Motorola xtnid not transmitting
This can be a sign of a bad or poorly charged battery. Trade batteries with a known good unit to see if the battery solves the problem.
Secondly, check your programming to be certain the radio is programmed to match the others.
Lastly, if neither of these solve the problem, your radio is likely in need of repair.
Feb 24, 2014 | Motorola XTNi Two Way Radio
Where can I get an operation manual for this item
You can visit this web page , and on the extreme right hand side you will find the user guides and operation manuals for this product..
http://www.motorola.com/Business/XU-EN/Business+Product+and+Services/Unlicensed+Two+Way+Business+Radios/XTNi+Series/XTNi_XU-EN
Jan 06, 2012 | Motorola XTNi Two Way Radio
Need xtniimanual manuals
First of all, thank you very much Colin for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNi%20Manual%20EN.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Intermmitant transmission on a Motorola xtni radio
Best regards.
Mar 09, 2011 | Motorola XTNi Two Way Radio
2) Easy Cloning
separately.)
Best regards.
Dec 03, 2009 | Motorola XTN 2-Way Radio
Motorola XTNi two way radio red light on all the time
The XTNi is a European version of the Radius CP110 and the Spirit RDX series. This unit is user-programmable. It is possible the radios you have with the same symptoms have a programming issue.
There are 3 ways to program the radio: 1) using the CPS software and cable, 2) using the 6-unit charger as a cloning station, or 3) using 2 single unit chargers linked together via a cloning cable. It is also possible to change limited programming features by hand.
We suggest you take one of your XTNi radios which is functioning correctly and clone the codeplug (copy the programming) into the non-functioning radios to see if it clears the problem. If not, the unit should still be under warranty. Take it back to the place where you purchased it and see if you can get it repaired under warranty. (This unit has only been available for about one year, so yours should still be under warranty.)
One other issue might be effecting the radios, which would be rare to happen on more than one radio at the same time. This would be "lock in transmit". You could tell if this were the case, because the radio's display would not change when you press any of the buttons. This problem would also require repair.
Sep 18, 2008 | Radio Communications
Motorola XTNiD
Hello Umtali,
What you describe could be the result of the radios being incorrectly programmed by the dealer. Like most professional radios, the Motorola MTNiD requires delaer programming (using computer software) to set the channels and functions of the radio. If the radios were not programmed or were programmed incorrectly then an error such as the one you mentioned might occured.
You should contact the dealer about getting the malfuntioning radios reprogrammed. Or, you may be able to clone any working radios you have into the non-functional ones using the cloning procedure in the User's Manual.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 26, 2008 | Radio Communications
Motorola XTNi Two Way Radio Logo
235 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
