Question about Nikon D80 Digital Camera with 18-135mm Lens
D80 flash doesn't close
I purchased this camera used. i believe a screw used to sit next to the hole where the flash hook (on the bottom) fits into the top (flash piece). i'd like to see a picture of a working d80 and find out how/where i can buy a replacement part, if my assessment is correct.
in other words: what does a function d80 flash piece look like from the front, and where can i buy replacement parts?
hope this makes sense,
erik
    Novelist:
  • 121 Answers
Erik, It's a little plastic arm with a tiny hook that moves to allow the flash to pop up when you press the flash button on the front of the camera or select the built-in flash option.  You may be able to get parts direct from Nikon or if you have a good local repair shop they may have a parts D80 to cannibalize for you if you have the skill to put it together.  If you got the camera at a good price and don't really rely on the built-in flash, (one on the hot shoe is always better) then tape that puppy down with some electrical tape until the repair is done and shoot all you want, peel it back for the pop up when you need a fill in flash or you don't have the flash with you.
randy320sgi
Posted on Jan 02, 2009
I have a Nikon DC 60, the flash "pops" up but does
We have a solution for this on Fixya. Check the details below and it should fix the issue.
My D60 flash problem was that the flash would pop up, but would not flash. The release lever would keep "clicking"...it did no know that the flash was up. Since I was told that the min cost of sending it to Nikon for repair was $250, I downloaded a repair/service manual for the D60 from http://www.tradebit.com/filedetail.php/9029672-nikon-d60-service-repair-manual ($8.99)
This manual gives a step by step assembly and disassembly of the camera.
I actually lucked up and fixed my problem...
Problem Descripton/Solution (short version):
There was a tiny plastic collar at the flash hinge that got pushed back into the camera. This collar served to close a couple of contacts. I stuck a home made wire/double hook tool into the hinge clearance hole and pulled the collar out and snapped it back into place.
Problem Description/Solution (LONG version)
WARNINGS (based on experience)
1. Yes, the flash will still shock the **** out of you..even with the battery out. You will smell burnt hair/flesh.
2. Be careful of the tiny contact leaf springs. They are hard to bend back into the correct position.
3. The #00 screws are easy to strip out. Apply firm pressure, turn slowly, and make sure screw driver is aligned properly.
4. Proceed at own risk (to camera). Make sure your warranty really has run out. There are many ways to make things worse. You can back out now and buy an external flash.
All I had to take apart however was the top cover of the flash (two tiny screws on underside of the flash #00 philips head). I found that there are two tiny copper or gold "leaf spring" contacts that have to close to send a signal that the flash is up. These are located at the hinge where the flash wiring runs into a clearance hole into the camera (hole is a center of rotation of the flash). There is a small plasitc collar that fits into this clearance hole from inside the flash/camera base and through the flash housing at the pivot point and snaps into place via 2 plastic hooks or tabs (download/see repair manual). This collar serves to secure the flash housing to the base but also has a tiny pin sticking out that catches one of the contact leaf springs and closes the circuit. The problem is that this collar got knocked out of place and pushed back into the camera. I made a home made wire/double hook tool out of 22 gauge wire (see attached picture) and worked it into the clearance hole by pinching the hooks together and working it in. Go in above the flash wires (top of hole) since the wire path goes downward into the camera. With some work and luck I was able to hook the edge of the collar and pull it back out and snap it back in place.
I then put the flash cover back on and everything still seems to work.
My Hook Tool....
Let us know if this resolved your problem.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | Nikon D60 Digital Camera
The flash is spring loaded and does not fully open when the release button is pushed. Must be manually held in upper position in order for the flash to work. Help me fix it
The Spring mount breaks in the flash and loses tension.
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable U shaped bracket that will slide over the broken plastic bracket and drill a tiny hole in the side where the spring will clip in.
make sure it fits really well and then epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash
Oct 25, 2010 | Fuji FinePix S700 Digital Camera
My Nikon D60 flash has stopped working despite being in flash mode. Any ideas?
My Hook Tool....
Sep 12, 2010 | Nikon D60 Digital Camera
Nikon D80 flash won't pop up
Must be a problem with the flash lock. Try to pop up the flash manually using the flash button located at the top left of the camera beside the flash. If this does not work, you may need to have the cam serviced
Jun 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 - My (built in) Flash will not pop up.
That is just a mechanical problem. There is just a little hook holding the flash and it retracts when you push the bottom to pop up the flash. I'm sure it can be easily fixed, never the less your camera store or Nikon should take care of it. So take it back to the place you bought it.
Jun 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
My fujifilm s5700 has a small problem... The flash itself works fine, the light that is, but it does not automatically pop up. It pops up about a milimeter or so, but not enough to be functional. If I...
The Flash Spring mounting breaks
Dec 31, 2008 | Fuji FinePix S5700 Digital Camera
Compare the Nikon d80 to the new d90. Can I use all my manual focus lenses from my Nikon film cameras? Also, all my filters and flashes.
All old lenses will work on the D90 the same way they work on the D80. Filters depend on the lens -- they either fit or they don't -- the camera has nothing to do with that. I wouldn't use old flashes on new DSLRs.
There really is no difference between the D80 and the D90 as far as lenses and flashes are concerned.
Sep 22, 2008 | Nikon Cameras
Pop up flash nikon D80
There is a small hex screw on the underside of the flash pop up... next to the latch. I gave it a half turn and presto... fixed...
Jul 07, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 using Bower AF 724AFN
I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
May 22, 2008 | Bower (724AFN) for Nikon Flash
Mating Metz 60CT4 to Nikon D80 camera
The 60CT-4 was not made for digital cameras.
It does TTL on film not on CMOS or CCD sensor.
Alexander
atdlee@netzero.com
Nov 22, 2007 | Metz Mecablitz 60CT4 TTL Flash
Nikon D80 Digital Camera with 18-135mm Lens Logo
128 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
