Question about Dell Axim X51v Pocket PC
Wifi is not working
I cannot access my wifi at all... i've noticed that when i enable my wifi, the bars at the bottom of the screen still show up, but never turn green anymore. what can i do to fix this? ive attempted to reboot the whole pocket pc, but that doesn't seem to work? thank-you
    Master:
  • 409 Answers
Have you ever been able to access wireless or is this a new installation?
Posted on Oct 24, 2008
Upside down screen on ipad
The Auto-rotation setting must be disabled. Enable it on the settings menu. Or if your tablet is running iOS 7, then enable auto-rotation on the Control Center. Simply swipe up from the bottom of the screen to launch control center. (It is like the opposite of pulling out Status Bar or Notifications Bar above.)
Apr 22, 2014 | Apple iPad 2 Wifi 16GB
Enable wifi
in labtop you'll see that kind of bar in the left low corner of the screen like phone signal bars there click and see what comes out whene you see your wifi's name click in it and type your pasword
Jun 11, 2013 | Dell Latitude E5410 Laptop Computer PC...
How to turn WIFI back on on Toshiba Satellite C675-S7200 Laptop
May be a faulty wifi card.
But check Adapter settings in control panel to ensure wifi card is "enabled" and check device manager to ensure correct wifi driver is installed.
Oct 12, 2017 | Toshiba Satellite Computers & Internet
My WiFi will only work when used with a cable to my usb port
Looks like your wifi is turned off.
Check its enabled on your router. search how to access it in google, its easy enough.
If you dont have a wifi icon in the bottom right hand side of your screen, turn your wifi back on try control panel, networks, you should be able to see if wifi is off and how to turn it on
Jul 11, 2012 | Acer Aspire One A150-1049 Notebook
I disabled the wireless (wi-fi) using the shortcut key.now i want to access wi-fi but unable to start using the shortcut key..wht exactly happened? did the driver had been uninstalled or wht? plz tell wht...
It should toggle. I don't think the driver would get uninstalled. Usually it's a switch (on Acer) or a Fn (Wifi icon Button) that turns Wifi on or off.
You may have to search for networks by clicking on the signal bars on the bottom right part of your screen, in order to connect to the Wifi network that is at your location.
Jan 21, 2011 | Dell Inspiron 710m Notebook
Hello, i have just bought a Chinese copy of iphone 3g, but i am not sure which company has made this clone or what cpu is used inside... i bought this phone only because i wanted a cheap phone with wifi...
access point is a code of wi fi without it u cant to wi fi. some its shows connect but its connected its not only in mobile,but shows in pc also. its just because of internal settings. if u want to check ur mobile then u should go a place where wi fi is working like college etc. and u should know the code of wi fi. then set ur settings with code. good luck.
Dec 31, 2010 | Computers & Internet
Cannot turn on wifi on T400. Intel 5100 card
Is the "broadcast-tower" light on (the leftmost icon on the lite-bar below the screen)? Have you got an available/working WiFi router? Have you been able to choose a network to connect to? My T400 works fine when all the above are enabled..
Jun 18, 2017 | IBM ThinkPad G41 Notebook
I cannot establish a working WiFi on my ASUS A639 PDA
You can simply follow the first 3 steps of this (http://iris.nyit.edu/oit/academic/FAQ/faq/2wireless/20026/20026.pdf) tutorial. After that, you should see your home wifi name in the list (as in the photo in the tutorial.). You should first connect to a network from this list (possibly with a wifi password), then it should connect automaticly evertime you swtich on wifi. After you have successfully connected to a wifi, you should see the wifi icon changes in the task bar. Hope this helps.
Apr 28, 2009 | ASUS MyPal A639 Pocket PC
Connect to the Internet
ok, this is a little technical, dell decided to make a complicated WiFi system for this, but once ou get the hang opf it you will be able to connect in no tim.
1. push the WiFi button located on the lower right side , it kind of is flush with the body
2. wait about 20 seconds, if the WiFi meter in the lower right corner of the screen does not change the you will have to go deeper into the system.
3.hopefuly you have noticed the blue light flashing by now, if it has an erratic flash , it is searching for a signal
4.no wifi yet? ok use the stylus to tap the wifi meter bar on the screen, this will show a menu consisting of a (WiFi radio on/off option, edit profiles option, WLan status option, site survey option, advanced, and versions.
5.tap the WLan staus option, this will bring you to the menu, this menu can also be accessed by going to settings. anyway look at the bars for link quality and strenghth, if they have a little bit of blue or none at allgo to site survey at the bottom of the screen
6.this menu shows al the available wifi networks in your area, ifnone show up, and you know you are near one tap the profiles setting, this will show all the nearby sites you can tap and hold any of these sites and manually connect to the internet that way.
7. I warn you , the dell x30 is a little wonky a great PDA and usually works great for the internet but sometimes it jsut plain refuses to actually connect to a site, even though it has a connection. I haqve found the best way to cure this is to do a soft reset, and reconnect.
If this still doesnt work for you, feel free to repost this question or email me, i might be able to help with some more details
Mar 11, 2009 | Dell Axim X30 Pocket PC
Dell Axim X51v Pocket PC Logo
83 people viewed this question
Alun Cox
