Question about Ambiance Designs Heating & Cooling
Ambiance 16 seer unit frozen
My outdoor unit on my Ambiance Eco Green 16 SEER unit has become so frosted over, that I am unable to get the indoor temp above 68deg. The unit is supposed to have an auto defrost, based on the manuals, but I can't figure out how to manually kick it into gear. It is 20deg outside and I've even tried leaving the unit off, but my apt has already dropped into the 50s in the past twenty mins. Help!
  • Ambiance Des... Master
  • 1,253 Answers
This sounds like a heat pump. If so, it sounds that the unit is not staying in the defrost mode. Heat pumps have a temp sensor so when the outdoor unit goes into a defrost mode, this temp sensor takes it out of the defrost mode when the temp reaches a set point to ensure there is no more frost. Usually about 51 degrees as a general rule. I would start there.
Posted on Jul 28, 2017
3 Suggested Answers
james3751
  • 614 Answers
SOURCE: Looking 4 a minisplit - heating & cooling - 12,000 btu 16-20 SEER
I have been doing this for 45 years and for the price the Amcor is the best because they send you everything you need to install unit. I just installed one for my neighbor18,000btus He paid 1000 included shipping. The tech support is great. Russ
Posted on Jul 26, 2009
When we put on the air conditioner it shows F1 or ERROR on the window. What is the problem?
Hi Charity, F1 is a communication fault, I hope this helps......... CHEERS..
1?Check whether the connection of the outdoor unit and indoor unit is one to one, otherwise connect the L, N and communication line of the indoor unit and outdoor unit one to one.
2?Measure whether the voltage between the zero line and the communication line is 18V-30AC half-wave signal, check whether the communication circuit on the indoor and outdoor electric control board has been damaged, otherwise replace it.
3?Check whether the LED on the outdoor power board has been on, otherwise replace the electric control board.
4?Check whether the unit is abnormal caused by the external interference, if it is, then find the interfering source, and removes it.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 10, 2016 | grunaire GSI241HXB / GSU241HXB 24,000 BTU...
Water leaking from unit
possible low pressure of refrigerant and freeze coil indoor unit, check filter maybe it's dirty
Jul 07, 2015 | YMGI R410A Ductless Mini Split 16 SEER DC...
Rheem error codes
error code 29 is a high pressure open. possible causes are dirty indoor or outdoor coil. indoor or outdoor fan not running, liquid line Freon restriction, or to much Freon in the unit.
Jul 30, 2014 | Rheem RPRL048JEC 4 Ton 16 SEER Heat Pump...
Heil Heat pump model # NHP218AKC2, I need the specs to replace an old unit in the other side of my duplex
I can help you on part of your question, the system that you listed above is a 1.5 ton unit, if I had the serial number I could give you the age of the unit. If it is a late 1990 model, then it is probably a 10 SEER unit, maybe a 12 SEER, if it is older than 1994 it will be a 8 to 10 SEER, but due to new federal rules, all new heat pump or air conditioners are at least 13 SEER. If you just replace the outdoor unit and leave the coil indoors, it will be mismatched and cause the unit to be less effeciant, and some problem in adjusting the Freon levels.
Ideal is to change the outdoor unit and indoor coil.
I hope this helps, I am new to this site, so I am still trying to get to the point, and yet give you the details that you need.
Sincerely,
Paul Gibson
Mar 29, 2010 | Goodman Heating & Cooling
I have a ruud achiever 10 model upgc-030jas and a high eletric bi
I'm using a calculation of VxA=W. Assuming your system is 240 volts and total amperage of system with 15 amps, I come up with 3600 watts or 3.2KW. Because the outdoor temp was above 35 deg F, the electric heaters probably did not cyle on to frequently if at all. Your calculation sounds reasonable to me. To determine exactly how many KW your system is using, you will need to determine exactly how many volts and amps your unit is running at...both indoor and outdoor units if this is a split system.
I've included a link to a website that helps the homeowner to determine the KWh.
I hope you found this helpful and good luck in your endeavor! :-)
http://www.sci-ed-ga.org/modules/k6/elec/elec.html
Feb 26, 2010 | Heating & Cooling
Just had the haier 4 ton 13 seer outside unit installed. my inside unit is a payne and still in good condition.had a 4 ton 10 seer outside unit previously. my problem is the unit froze up the first night...
Your problem is that your 13 seer outdoor unit is not compatible with your 10 seer indoor unit, even though the tonnage is the same. The metering device on 13 seer indoor units is different. Most 10 seer indoor units do not have an expansion valve. When you change from a 10 seer outdoor unit to a 13 seer outdoor unit, you must, at the very least, change the from a fixed-orfice metering device to an expansion valve.
Jul 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Jul 25, 2009 | Heating & Cooling
Air conditioning spilt system
I have to know what the outside temp is and I also need to know the seer of the unit. It would also help to know what the indoor temp is as well. Generally your suction pressure or what you are referring to as the indoor temp will be about the same. Let's say your indoor temp is 75, then your suction pressure should be around 75psi as well. Based on the suction pressure you just gave me, I would bet that the temp is not 38 degrees. With the suction at 38 and a low head or high side, you may be low on refrigerant. 110 is a little low but again, this depends on the seer rating of the unit. A higher seer will have a lower head.
Apr 08, 2009 | Heating & Cooling
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
Power consumption excessively high
Yes a higher SEER can help reduce electric costs. However. In most cases this will require changing both the indoor and outdoor units. In other words if you have a 10 SEER matched system and only upgrade the outdoor unit to a 14 SEER you will not get exactly 14 SEER efficiency. They must match.
Before excepting bids on new equipment I would first higher a licensed company to measure the Heat gain/loss from you house. This information will tell you if the current system was originally sized correctly. The improper sizing can lead to high electric bills as well. I hope this helps.
Jun 16, 2008 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Ambiance Designs Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you an Ambiance Designs Heating and Cooling Expert? Answer questions, earn points and help others
