Question about Vehicle Parts & Accessories
I have a VIPER 785 XV auto security system and my car starts up automatcally at 9:30 AM everyday. How do I prevent this from happening?
My car starts up automatically at 9:30 AM everyday. I have not programmed it to do that. On my remote display in the upper left hand corner below the time display it shows the following icons from left to right: on the left is the transmit range indicator with no waves around it, the unlock icon in the middle followed by three waves. I have tried pushing the lock and star buttons simultaneously, but does not work. I have tried turning the ignition to the on position when the engine is running and that does not work.
SOURCE: Viper 791 XV Automatic Start Not Working
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Posted on Nov 08, 2008
  • 22 Answers
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Posted on Dec 04, 2008
SOURCE: viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Posted on Feb 28, 2009
VZW
SOURCE: Viper remote stopped working!
First things first. Check the fuse that powers your alarm system. If that seems to be ok then try the next simple option. Open the hood and disconnect the negative battery cable. Then turn the ignition to the start position for approximately three minutes. This will allow for any remaining energy to dissipate from your system. Now you can reconnect the negative cable. *** Before trying your alarm *** turn the ignition on and off 3 times quickly. Make sure you don't start the vehicle. Now you can exit the vehicle and try your alarm. FYI you can always stop at a nearby Best Buy store for additional assistance. They are usually very helpful. Good luck and best regards, Rico...
Posted on Sep 13, 2009
localwonder
  • 6784 Answers
SOURCE: Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Posted on Sep 27, 2009
I have a python alarm system on my car, somehow
What happened is your kids set the auto timer on your rem.srt. that function is built in for going on vacation and your batt.wouldn't be dead when came home. I have installed any new"dei"alarms but if you called a viper dealer they can walk you thru the process in minutes. Btw don't worry to much about it running it will shut off between 10-20min. That's built in the alarm. Hope that helps.
Oct 10, 2014 | Vehicle Parts & Accessories
Can I use a smart phone on this system
If your remote starter has a red bit writer/expresskit port then it has the ability to add a smart start (DSM 200/250) to the system.
Feb 02, 2013 | Vehicle Parts & Accessories
My viper car starter wont work consistantly lately,sometimes the remote works and i will press it again and nothing,changed battery. its a hit and miss thing. im confused.its a 130 xv model
sounds like a dirty remote. if you open it up and clean the contacts with rubbing alcahol (get the back side of the rubber as well) it should help
Mar 07, 2011 | Remote Start System
Car starts by itself even when the keys/fob were 100 miles away
Your Viper auto start is programed to Automatically Start at a certain time ..... check your manual and disable auto start,
you didnt say which model you have but you can download a manual from here...
http://www.viper.com/Support/
Nov 19, 2010 | Remote Start System
Car is completely locked down
Let's hopethat the installer actually put in the valet switch for the Viper! Lcate the valet switch. ALWAYS put mine down by the e-brake lever under dash. (I assume that the alarm is going off? If not, go to next step.
Find the alarm/start brain under dash. Unplug main 6 pin 12 gauge wire harness. Wait 5 minutes, then re-appy the power plug. Alarm "may" go off, then try again.
Hit me back if you need further assstance. TTYL
Larry T
Winona Lake, IN
Jan 28, 2009 | 791XV The 791XV is a 2-way Security and...
Nov 17, 2008 | Viper Security and Remote Start System...
Nov 05, 2008 | Viper Security and Remote Start System...
Viper 160XV Problem
How to programing the remote for viper 160 xv.Thanks.
Jul 02, 2008 | Viper Security and Remote Start System...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
