Question about Sub-Zero 632 / S
Sub zero 632 s frig freezing everything
We are having a problem with the refrigerator freezing everything. the temperature is set at 40F. I have recently cleaned the motor and fan for the frig, but it is still freezing the produce drawers and now in the back there is ice forming. How do I fix this problem? Thank you for your anticipated help!
  • 833 Answers
First, is the temp really 40??  Get your outside thermometer and stick it in there.  You may get a surprise.  If so, see if the thermostat will respond to any changes.  It is possible that either the sensor or the electronics have gone bad...I'd vote for the sensor.
the other possibility might be low gas...but I'll want to see what the temp in the unit is and whether the changes you make do anything.
Posted on Nov 15, 2008
Sub-Zero Model 532. The refrigerator section is freezing up. I've vacuumed the condenser area but it's still happening. Adjusting the temperature doesn't help, either.
The defrost cycle is not working there should be defrost board also should check the defrost bimetal and check heater
May 10, 2016 | Frost Refrigerators
We have a Sub Zero 249RP Refrigerator that - though the temperature is set at the lowest point - keeps freezing the food inside. Any ideas?
Um, try setting the temperature at a high point.... My subzero frig works on the "higher is warmer" idea.
Oct 29, 2013 | Sub-Zero Refrigerators
Sub zero 632
3C on the fridge side
-18C on the freezer side
Sub-zero repair in Orange County, CA
Jan 30, 2010 | Sub-Zero 632 / S
I have a 7 year old sub zero 632. The
The sub zeros I have worked on have a compressor for each side. Is your fan blowing. You may have a defrost timer or heater. Possible low on gas but thats not very likely the sub zeros are made very well. Check to see if fan is blowing. Check condensor coils on top to see if they are clean. Check to see if your condensor fan is blowing. These are just possoble problem you can check if every thing looks good. Call a service tech ask for free estimate on repairs. Rus
Jul 06, 2009 | Sub-Zero 632 / S
Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 532 ice buildup in frig
Not enough refrigerant in sealed system or/and restriction in capillary tube.
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Jul 30, 2008 | Sub-Zero 632 / S
WHATS THAT NOISE??!!
more likely a bad compressor, which is more sensitive to temperature extremes...may be cheaper to replace the frig.
Jun 10, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero 632 / S Logo
185 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
