Question about Ovens
How do you know if your oven is hard wired in or plugged in if can't see it?
  • 409 Answers
The wiring should go to a cooker switch box...usually found at the back of an adjacent cupboard or on the wall. This will usually have a large red switch with a power indicator light and a standard switched socket.
On most installations of seperate oven and hob...the hob will be hard wired to the big red switch and the oven will be plugged in to the standard socket. So switch the socket off and see wether your oven is off...if the oven is connected to the big red switch instead then it must be hardwired...
Posted on Feb 13, 2012
OVEN TRIPS OUT
Posted this several years ago. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
If that doesn't work, you will need a new sensor, as we did. But when we installed it, we used the little plastic electric plug to connect it. Two days later it started acting up again.
The instructions said to hard wire it with two small wire nuts, but since it came with a plug it made sense to use it. Finally, even though it didn't make sense, I cut out the plastic plug and hard wired it. It's been about 3 years now and we've had no further problems.
THERE IS SOMETHING WRONG WITH THAT LITTLE PLASTIC ELECTRIC PLUG. YOU MUST NOT USE IT. HARD WIRE IT.
Mar 04, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Thermostat on hot point stove
Posted this several years ago. Don't know if it's the same oven. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
Jan 18, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Kenmore 790
I could be wrong, but from your limited description I am assuming that you cut the cord and wired direct to the box. You may not have 240 volts at the box and are trying to connect it to 120 volts. A dark green wire is the safety ground. The white is neutral and two colored wires are supply lines with 120 volts ( average) EACH. Better get someone in there that knows electricity and how to make proper connections to the proper voltage. Otherwise you are asking for major trouble.
Jun 26, 2013 | Ovens
Dacor Oven Thermostate problem
The replacement temp sensor could be defective.
Mar 03, 2017 | Dacor Ovens
My kenmore double oven model 41165 stopped working after a minutes power outage. It was cooling down the time after the self cleaning cycle. It is hardwired into a 40 amp breaker. I tried tripping it but...
its more than likely a burnt wire ,, turn off the breaker its hard wired into, ( you might want to set up a plug system for it at this time if that's possible, ) open the back where the plug goes into the unit, and check for power, if you can use a multimeter that's cool, If your unsure as to how to check it, you might want to call a service repair
Jun 12, 2011 | Kenmore 47793 Electric Double Oven
Whats the difference between a hard wire and a plug in for a oven
A "hard wired" oven means the 10 gauge (3 conductor with ground) cable from the main service panel (breaker box) is connected directly to terminals on the oven. A "plug in" oven means there is a wall outlet into which plugs a cable connected to the oven terminals. The plug on the cable would be very similar if not identical to the plug on the cable used on a clothes dryer.
Charlie
Mar 13, 2011 | Ovens
I need to know the amps needed for this oven
If it is a single oven, then it can be plugged directly into a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired, protected by a minimum 40 amp fused circuit.
Oct 27, 2010 | Ovens
Hard wired or plug in
if i bought a single oven with a three wire cable coming out the back with no plug, which i know is meant to be hard wired, are you saying i could fit a plug to this and plug it into a normal 13amp socket, reason i ask i ahve an oven which has packed in and it plugs into the wall at the back, if i fitted a plug onto the cable from a single oven below 3kw then are you saying i can do this?
Jan 20, 2010 | Ariston Technologies Ovens
How connected
You can connect it either way. However I would recommend either split-bolt connectors or ring lugs w/ bolt and nuts rather than wire nuts, if you choose to hard wire it.
May 14, 2009 | GE Ovens
Ovens Logo
573 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
