Question about JVC LT-23X576 23 in. LCD Television
TV Won't Turn On - Think Fuse Blown
My JVC TV (Model Number: LT-23C50BJ/wide LCD Panel TV) which I purchased 15months ago stopped working. Specifically, I turned it on then shortly thereafter, it went off. I heard a popping sound like when a bulb goes out. There was also a funny little smell. With that, does anyone has any ideas on what might have happened? Also how to repair? As this TV is relatively new, somewhat surprised. More importantly, I have no idea how to fix or what the possible repair charges would be. HELP!!
    Champion:
  • 217 Answers
The set needs to be taken apart and visually inspected, look for a burnt spot and it could possibly be fixed by replacing the blown component, or else the wholr PCB must be replaced
Posted on Feb 18, 2007
What are the eeprom codes for jvc tv lt-42x579, eeprom m16
The number of the memory IC will be printed on it. Usually, it will be in laser printing. When replace it, be sure to replace with exact number printed on it; otherwise, it won't work.
Will look somewhat like this. May be a DIL type or an SMD type.
Sep 15, 2014 | JVC LT-42X579 42 in. LCD TV
Power supply board
There is no one that handles that part that I can find.
Sep 30, 2013 | JVC Lt-32p510 32" Lcd Tv
Jvc lcd picutre won't show
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
Sep 03, 2012 | JVC LT-42X579 42 in. LCD TV
My tv will not turn on
I have had the same problem with another JVC television and I now seemed to have established that there is an internal fuse which has blown.
I have removed the back panel and got the fuse out. It looks as though it has blown but I have now asked on here for a specification of that fuse.
Assuming you have checked the fuse in the plug, I would see if you can locate another one internally by removing the back panel (be careful not to touch any of the metalwork - just in case !)
Nov 21, 2011 | JVC LT-32X506 32 in. LCD Television
Jvc model no. LT-32p679. cable line was struck by lightning now tv wont turn on
Cable system is grounded to electrical system. Most electronics have fuses inside. Open it up and look for blown fuse.
Oct 13, 2010 | JVC LT-32P679 32 in. LCD TV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Remote control (i hope)
The IR sensor in the tv is probably weak, you could make a mountain out of a mole hill and get it replaced (using your friends receipt ^_^) but there's nothing to be done about the sensor.
Feb 05, 2009 | JVC LT-32P679 32 in. LCD TV
Remote control for JVC TV stopped working
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
Dec 10, 2008 | JVC LT-26X575 26 in. LCD HDTV
JVC LT-23X576 23 in. LCD Television Logo
193 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
