Question about LG KU990 Viewty
Yellow screen and says refreshing will not turn off
  • need help please
  • Anonymous Mar 07, 2009
    yellow screen and says refreshing will not turn off
    Problem Solver:
  • 8 Answers
Hi open EFS connect phone with USB click EFS explorer click your phone on the top half of the box, find a folder u named TOTO rename it to LGAPP click disconnect warning box may appear just click yes if so now your phone should restart and work normally ;) if not, contact me at my youtube account: addol95
hope it works!
Posted on Apr 19, 2009
& I Have The Same Proplem
Posted on Nov 18, 2008
4 Suggested Answers
LG_Authority
  • 65 Answers
SOURCE: HOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MOBILE PHONE SHOP HAS FAILED TO BE ABLE TO RE FLASH THE FIRM WARE PLEASE HELP
a2ee4a7.gif LG_Authority
conect your phone with the usb port.
start in windows the program EFS MEDIA BUILDER by AKOM1976.
select connecton and after that you choose efs explorer select connection.
Now you see the files on your phone
maye there is a folder named as TOTO
be sure that this folder is on your phone!!!
If it does delete the folder named as LGAPP
after that rename the folder named TOTO to LGAPP
richt click and choose refresh.
now exit the efs program.
Turn your phone off and then after a few seconds on
the phone will startup normaly as always and its normal asual.
I hope this will work or you have to back up with the LGMDP euro
an after that choose restore and choose the image file *.nv2
This will work!
you can try a software update at http://nl.lgmobile.com/web/web.product.manualSoftwareRF.laf
This software update is at your own risk.
Choose your model of your mobile phone and download it.
Fallow the instructions by the software update be patience
if you don't see anything it take a few moments.
Comment posted on May 04, 2009 No you have to see that the folder already exist on your phone
LGAPP and a nother folder TOTO if the phone starts up and you didn't switch the folder it make a new folder LGAPP without the programs so all the folders in the folder LGAPP are emty.
So thats why you have to be sure that the folder TOTO is already exist on your phone.
And if you have a backup of the folder TOTO you can check if the maps are empty or not.
These files have to be in the map toto on your pc.
These are the file names that is logged by EFS explorer, you can see the folder names and the files that are in the folder map exist
Check if these file are located in the folders of your phone if not
delete the emty folder LGAPP and make a new folder named TOTO open that folder.
Now read the files that is on your pc in the map TOTO.
This folder have to be the files in it and doesn't suppose to be empty.
The files you need to see on your phone with EFS explorer looks like this:
LGAPP
LGAPPCommon
LGAPPDRM
LGAPPDRMCERT
LGAPPDRMCERTCERT
LGAPPDRMCERTCERTdevelopcert.cer
LGAPPDRMCERTCERTdevicecacert.cer
LGAPPDRMCERTCERTdevicecert.cer
LGAPPDRMCERTCERTdevicepkey.cer
LGAPPDRMCERTCERT ootcert.cer
LGAPPDRMCERTcmla
LGAPPDRMCERTcmladevicecacert.cer
LGAPPDRMCERTcmladevicecert.cer
LGAPPDRMCERTcmladevicepkey.cer
LGAPPDRMCERTcmla ootcert.cer
LGAPPDRMDPRO
LGAPPDRMDRMCERTTYPE.TXT
LGAPPDRMID
LGAPPDRMIDSYS
LGAPPDRMISAMDB
LGAPPDRMISAMDBCertDB.bin
LGAPPDRMISAMDBCertDBKey_CTYPE.bin
Etc.
[ File Renamed ] LGAPP->TOTO
These files are on the pc:
TOTO
TOTOCommon
TOTODRM
TOTODRMCERT
TOTODRMCERTCERT
TOTODRMCERTCERTdevelopcert.cer
TOTODRMCERTCERTdevicecacert.cer
TOTODRMCERTCERTdevicecert.cer
TOTODRMCERTCERTdevicepkey.cer
TOTODRMCERTCERT ootcert.cer
TOTODRMCERTcmla
TOTODRMCERTcmladevicecacert.cer
TOTODRMCERTcmladevicecert.cer
TOTODRMCERTcmladevicepkey.cer
TOTODRMCERTcmla ootcert.cer
TOTODRMDPRO
TOTODRMDRMCERTTYPE.TXT
TOTODRMID
TOTODRMIDSYS
TOTODRMISAMDB
TOTODRMISAMDBCertDB.bin
TOTODRMISAMDBCertDBKey_CTYPE.bin
TOTODRMISAMDBDCtxDB.bin
TOTODRMISAMDBDCtxDBKey_DID.bin
Etc.
and its fine to have these as my back up.
If your folder LGAPP on the fone is emty don't worry write the files from your pc to the phone Make a folder named TOTO.
and write all the files include the foleders in to TOTO at your phone.
When you fineshed. Rename LGAPP >> XLGAPP
Rename TOTO >> LGAPP.
Delete the folder XLGAPP.
Refresh and disconnect and you will see the phone startsup in
a normal mode. As you can see I delete th folder LGAPP that was empty.4f0b046.png
Now I read the folder that is back it up on my pc to the phone.
Now when its finished I renane that folder to LGAPP.
When yo finished diconnect the phone by clicking disconnect.
So the phone start automatical again and now its running in norma
mode asual. I hope this will work for you.
Posted on May 08, 2009
LG_Authority
  • 65 Answers
SOURCE: yellow refreshing screen viewty ku990
Take look here:
http://www.fixya.com/support/t2141371-screen_broken_cannot_get_contacts_ku990
This solution will help you out.
SOURCE: yellow refreshing screen on my ku990
i had the same thing happen to my mobile you need a new firmware file use v10j it can be found on my great phone .com but i found the easyest way to find this is to google it and ask googl were can i get firmware v10j i thik the first answer is a link to mygreat phone ,com link to it and download this firmware next you need the flash software wich is LGMDP download this bit of software you need the usb lead for the next bit open the LGMDP prog select the the one that ses open you have a choice of us open or euro or h3g nowwhen you connect your mobile you should get a screen come up with connect at the bottom left hit it now you should get a screen with a load of empty spaces with a brouse button at the end hit the first brouse button in the list . now you need to go to the place were you saved you firmware v10j click on this file it should fill in all or every 1 except for media and modual and that will be in the same firmware file under others when you have done that you wiil get a list saying true and 1 should say faulse i think at the bottom it should say confirm hit it your mobile should to be firmware flashed this shold take about 20 mins PS the little blue box should say normal mode if it said emergency come back to me
Posted on Jul 12, 2009
I can't connect my lg viewty with the refreshing problem to my pc
please try to connect your lg to some some another pc, perhaps it will work, keep it up
Jul 13, 2009 | LG KU990 Viewty
Lg viewty yellow refreshing screen
you need to reflash it , you can either take it to a mobile repair shop or attemt to find the firmware yourself
Jun 01, 2009 | LG KU990 Viewty
Yellow refreshing screen on my ku990
May 31, 2009 | LG KU990 Viewty
My lg ku990 has yellow sreen
iyourfatherl
maybe this will work.
This will work!
Mar 14, 2009 | LG KU990 Viewty
Yellow Screen with Refreshing on it!!
it is because your phone has become corrupted . Refreshing comes because it is not able to find RAM . Go to a nearby shop if it is under warranty it will cost you nothing if not still a very little cost will be needed to paid. person will connect your phone with his computer and change the software in 15min. pls vote me thank you
Feb 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Yellow screen saying Refreshing
OK I SOLVED IT.... GO TO THE EFS BACK AND CONNECT YOUR MOBILE... THEN PLAY WITH THE TOTO...LGAPP...REFRESH...DISCONECT AND WILL WORK...
The problem is with the new data you've inserted...
Btw my viewty have 4months and i tryed this 5times before posting..Good luck on restoring
Apr 09, 2008 | LG KU990 Viewty
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa screen turns black after "refreshing database"
how about updating the firmware?
OOOOHHHHH
now we are getting somewhere
( how could someone not figure that out.... ha ha ha)
Dec 20, 2007 | SanDisk Sansa e250 MP3 Player
LG KU990 Viewty Logo
404 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
